- 8:30 AM
- Feb 27, 2016
- SW MO
Lol..Well if it does I have an 88 4x4 with 5speed you can have if you come get it.
Yes, total PIA. This one has a short in harness bundle somewhere,on the fender well. It shorts out the ignition module. It may go a month or a week just great then it won’t generate spark. It would go anywhere I wanted just couldn’t rely on it to start all the time. Local mechanic thought maybe a bump starter to bypass the switch & some of the wiring would take care of it but I just parked it. It is destined for the salvage yard.Lol..
Seems it’s missing on about 2 cylinders.,
Levi put new plugs and wires in it,,
Same miss.. may have to take it to an expert.
I saw where the distributor and rotor is located.,
And I ain’t goin there...!!!
Check and make sure valves are not stuck ,Lol..
Did the heater work??Yes, total PIA. This one has a short in harness bundle somewhere,on the fender well. It shorts out the ignition module. It may go a month or a week just great then it won’t generate spark. It would go anywhere I wanted just couldn’t rely on it to start all the time. Local mechanic thought maybe a bump starter to bypass the switch & some of the wiring would take care of it but I just parked it. It is destined for the salvage yard.
So if we load this thing with hedge splits will the axle shell??? Lol
Yes the heat worked, those old Rangers were always lacking in the heat department in my opinion. I will send you some pics tomorrow.Did the heater work??
If so, Levi May want to buy it off you.
I've always liked Rangers. Had at least a dozen of them. And yeah, the distributor on the 2.9's was a little problematic. It seems like every engine Ford makes you have to take the upper intake off to do simple stuff. 4.9, 5.0 and 351W you gave to take the upper intake off to change valve cover gaskets. I know on the 4.9, when you take the upper intake off you'd better be ready to drop another $100 just to replace other things while your in there because something else is going to go bad 2 weeks after you were in there.
Savage Axis XP.
Any way to make the trigger pull lighter?
Can yall even fit in that?
I got a narrow Dana 70 dually axle that would work real nice for that.So if we load this thing with hedge splits will the axle shell??? Lol
Barely... lol .Can yall even fit in that?
I think my Polaris has more room...
Lol
Yep he is young and limber.Have had several trucks that size and sold them for the sardine in a can effect.
Don't see a six and a half footer plus fitting in there comfortably at all.
Levi will have fun in that toy for a while
