JimBear
10:38 PM
IA
I need to get a power inverter for my truck & bring the Simington & some chains with me so I can work on them while I am sitting in line @ Cargill in KC... zzzzzz
Hinerman
10:38 PM
NE OK
I have gone to using radials. 10 ply if you can find them, from pickups. for trailers..
You can then go as fast as you want...
Thank me later.
Use truck tires!
What he said^^^^^^^
And iirc semi tires are in same 65mph zone.
Been looking for truck tires. The problem I am having is finding 10 ply, and finding tires that have the load rating I need for a 15" tire. Tire size is 205/75 R15...
moparnut88
11:38 PM
US
You can if you go to a 225/70/15. Just ordered some this morning for 47.01 each. 10 ply.
MACHINE
11:38 PM
Broken Bow, Oklahoma
Got cabinets painted today
About ready to install flooring
Sent from my SM-G955U using Tapatalk
moparnut88
11:38 PM
US
This is the machine I’m going to try to get next weekend. It’s an 09 cat 299C XPS high flow. It’s near Indianapolis.
This is the machine I partially traded my old machine for as well. It needs engine work. Spun rod bearing. But has new undercarriage. Has yanmar engine. More projects :) at least these make money. Lol.
stihl livin
Do the Dallas
10:38 PM
Upper Midwest
that is cheap. Here they run about 60+ a piece. Still debating going with the 14 ply of the interwebs but at 120 a piece not sure I want to do that. Wish I could find a set of 6 bolt 16 inch wheels and tires to see if they will work at 16s are much easier to come by in heavier load rating
birdmeter
10:38 PM
tulsa okla
I have been running 16 ply trailer tires. Original trailer tires lasted one year. These have been going 5 years. Need replaced next spring. Did have to change one under warranty. Tire was out of round. Oval shaped. Made truck shake.
were can i get some 16 ply tires.i replaced mine last year but 16 ply would last longer.
stihl livin
Do the Dallas
10:38 PM
Upper Midwest
Semotony
10:38 PM
The 225s are wider. Wouldn't I need a wider rim?
I've been running 205/14 z on cavalier no prob. Tire seller woodn't look for 215's I think it was, for Voyager mini van. Mounted fine, van's speedo is right on the money by the side of the road warning radar. Cavalier is sposed to have 185s I think.
Now when Mickey Thompson's get used it does make enough difference lol
JimBear
10:38 PM
IA
Those
Those Takeuchi machines are supposed to be about bullet proof. Everyone I have spoken with that have ran them have just raved about them.
