- 5:48 PM
- Jan 3, 2016
- West of Kansas City
Those are nice.
^^ this^^^That is a very good static level for that depth . Is it 120 or 220? 220 is .ore efficient to operate. Wouldn't hurt to get the water tested for contaminated like ecoli.
I got a large pile of board pieces leftover from the kids’ deck project.Those are nice.
So I’m gonna start selling butcher blocks and cutting boards.. custom sizes...
Wonder if hedge would make a good one..??
Got the well pump pulled today. Motor had an open in it. No worky worky. Found that the bottom 8 inches or so was sitting in mud at the bottom. That didn't help matters. Measured the well depth at 62 feet with the water level 20 feet from the top of the well head. Next weekend the new pump gets installed at 10 feet from the bottom.
Old pump was 3/4 hp 220 volt.That is a very good static level for that depth . Is it 120 or 220? 220 is more efficient to operate. Wouldn't hurt to get the water tested for contaminated like ecoli.
I have a grip for keeping the pipe from falling down the well while you pull or install it.I'll be getting it tested as soon as I can get some water up and out of it.
I rigged up a cross beam inside the new well house, mounted a crank type boat winch to it and a couple of eye bolts for the safety ropes when the new pump goes in. The old one was not installed with safety ropes.
Made up a way to grab the pipe (which looked to be schedule 80 pvc) using a wide load strap.
Grabbed hold of the pipe with it and started cranking. Straps got tighter than a banjo string. Wouldn't budge an inch. I'm thinking, oh crap. That pump is stuck. Released the tension and worked on other stuff for a while. Went back to it and cranked it back tight again! Good grief!
Grabbed hold of the strap and started shaking the living daylights out of it. After about 2 minutes of shaking the line here it came. Cranked it up 5 feet and locked it there until my son arrived to help pull it the rest of the way. Took about 2 hrs to get it out. Looking at the pump it appears the bottom 8 inches or so was in the mud at the bottom of the Well. The intake screens were probably about 6 inches above that. I'm no expert on wells but I know it's not good to have the pump on the bottom.
Anyway, next weekend will get the pump installed with continuous 1 piece 1 1/4 pipe up to the tank. For the foreseeable future I'll just have a spigot on the outside of the Well house.
They are handy. we have 2 or 3 in the family.I have a grip for keeping the pipe from falling down the well while you pull or install it.
It is the yellow piece in this picture
You are welcome to borrow it if you need it.
My new pipe going in I don't think will be a problem (famous last words). But, if I need it you're not too far from me.I have a grip for keeping the pipe from falling down the well while you pull or install it.
Are you using the black poly pipe?Fortunately, my new pipe is 100 feet long one piece. Well is 62. If it falls going in I'll still have 40 sticking out. I'm not cutting that thing until I have too.
I hope not it won't take the toque of start up.Are you using the black poly pipe?
