- 8:00 PM
- Sep 4, 2018
- Central Kansas
Good morning fellas! Try to stay cool the next few days!
Yes, dinky and way overvalued.
Just slap a Farmertec MS180 in there Steve. I hate to see a talented man waste time.
Just had some ceamsickles crapped out on my driveway.I've been needing some bonfire material.
And a little Husky.![]()
OK Carl, I'll be like the rest of the rookies that post "what's it worth" and "what mix ratio" posts.Took a spell to find Steve’s post. [emoji57]
An 041 will fetch a high bid around the Midland Empire. Well above their actual worth. [emoji2960]
I can see now why I thought the box contents were a 017 type. [emoji57]
Sling it and pray..Very cool Machine!
Although I am a firm believer every young man/woman should learn to
drive and shift an old 10 or 20 series with Syncro Range![]()
About five six weeks ago I left this with Jeff for when the SnapOn truck comes by.
I had been using that ratchet since my teen years and the direction lever jumped ship. It has spun lots of bolts.
Ratchet fixed up spiffy and didn’t charge anything. [emoji16]
Planer that size is 3-phase power. An open side sander @ 20" give 39" according to WoodCraft in St Louis. $60 an hour minimum 1 hour they informed me awhile backYou need a wider planer now with that wide mill
That is a very good static level for that depth . Is it 120 or 220? 220 is more efficient to operate. Wouldn't hurt to get the water tested for contaminated like ecoli.View attachment 245662
Got the well pump pulled today. Motor had an open in it. No worky worky. Found that the bottom 8 inches or so was sitting in mud at the bottom. That didn't help matters. Measured the well depth at 62 feet with the water level 20 feet from the top of the well head. Next weekend the new pump gets installed at 10 feet from the bottom.
