- 3:00 PM
- Oct 21, 2016
- Kansas
I need some input on that chain brake
There over rate you just need to take it off
Which models are the Mac and the bigger green Pull-on?I loves me Husky 50 white top ranchers.
Put a .325" x 18" on it.[emoji108]
Put it up for trade?
We have others also.
Fixed it for you Doug!!!Snowblower d handles aren't strong enough. They rip in two. Snowmobile d handle is more betterer.
@Locust CutterOn another note, I took an ailing friend about 1/4 cord of wood as he was out and was going to need the stove to help through the cold snap. I will likely be going to cut a bunch of dry Hedge soon and gt him at least 1/2 if not 1 full cord to get Him through what will likely be His last Winter...
It's a crappy deal, but that's life.
I use a brass hammer LIGHTLY with the nut flush with the end of the threads, BUT if it doesn't come off in three... I pull it.I got a brass hammer that has worked great for me as a puller.
If you take the fuel line off a carb with a pressurized tank it's gonna unload it's contents. .... vents let air in not outIt sprayed the entire tank at me. Could that pressure be why it wasn't running worth a *f-word?
Of course, most people will crack the fuel tank open before it unloads its contents all over you.If you take the fuel line off a carb with a pressurized tank it's gonna unload it's contents. .... vents let air in not out
Pulled the carb to fix some issues with it and the *frenching tank sprayed all the fuel on me.
I do believe the first one, the tecumseh, is a Barker. Made in Spfd Mo. Looks identical to one I have. The second is a Mac 33 or 35.Hey fellas, does anyone know what this is. The first one. It has a Tecumseh motor.View attachment 45371View attachment 45372 The back one.View attachment 45373
It says Mac on the bar.
