- 5:54 PM
- Dec 28, 2015
- SE MN
Hermann.What part are you in?
Brenda and I would be honored to buy you lunch if it works for you guys.
Meet was in Columbia.
Thanks Chet!
Talked the landowner into letting me cut a nice clean sassafras.... because I ain't never milled one before...
Got five good 8' logs out of it.
View attachment 395829View attachment 395830View attachment 395831View attachment 395832View attachment 395833
Got the beans run behind the house..Good morning folks. Coffee & cereal then off to set augers & wagons for corn harvest.
It was growing down in a creek bottom with a bunch more sassafras but they were all kinky, this one was the only one worth cutting for sawlogs.I’ve never seen a straight sassafras tree..
Let alone a 40 footer..
Ida thought it was a poplar.
Cool!View attachment 395867
Levi and Ethan resurrected this dinasour from a barnyard.
They learned a valuable lesson..
just sitting still for years can be worse than it being used.
I’ll bet they replaced 10 bearings and countless sprockets and a few belts before they could put any time on it. Not to mention welding and patching augers.
But they managed to put 50 acres through it after that. Motor runs good..
Those were good machines. Agreed that sitting unused is rough on everythingView attachment 395867
The 22’ header might be overdoing it a little, but it’s what they had available..Those were good machines. Agreed that sitting unused is rough on everything
That’s probably a load for it it good beans, several guys around here used to run 20’ headers on 6620’sThe 22’ header might be overdoing it a little, but it’s what they had available..
Gonna have to go slow through 80 bushel wheat.,That’s probably a load for it it good beans, several guys around here used to run 20’ headers on 6620’s
