plcnut
Jesus is LORD
2:28 PM
Mansfield, Missouri
Good morning!
I finally bought a little tractor.
It is a Kubota 4610D. It is 46HP with Glide Shift.
Also got a John Deere 6' bush hog to go with it.
I can also get a nice heavy 7' box blade, but am concerned it may be too big for a 3200lb tractor.
What are your thoughts on the box blade width?
Should I look for a 6' instead?
moparnut88
3:28 PM
US
Good morning!
View attachment 271200 View attachment 271198 View attachment 271199
For light work you might be ok with 7’. 6’ would be sized better for your tractor. I can’t run a 5’ here in the sand but in your heavy dirt you might get away with a 7’. I usually don’t have a power problem it’s traction. Does it have loaded tires?
plcnut
Jesus is LORD
2:28 PM
Mansfield, Missouri
I am not sure if the tires are filled or not.
I reckon I could get them filled if I needed to.
moparnut88
3:28 PM
US
Would I fill the front tires as well, or only the rears?
Only my rears are filled but I’ve needed the fronts for traction several times. Don’t put sodium. Go with methanol. And my tractor is about the same size and 6’ covers my tracks. But doesn’t leave much over hang on each side.
plcnut
Jesus is LORD
2:28 PM
Mansfield, Missouri
Methanol?
I thought they used some kind of glycol?
I won't use the sodium. That stuff eats everything!
moparnut88
3:28 PM
US
Methanol?
The local guy uses that basically windshield washer fluid. You can use antifreeze. It’s just more expensive. The best is a product called rim guard. It’s beet juice. About as heavy as calcium but won’t rot your wheels. My guy said about 5 gals of methanol to a tire your rears size and the rest water. If you got a way to put it in you can do it your self. Save some money.
plcnut
Jesus is LORD
2:28 PM
Mansfield, Missouri
I have a mobile tire guy that can come do it for me.
I went ahead and bought the 7' blade.
He came down a little on the price, and it is much better quality than the $600-$800 new ones.
