Hinerman
5:18 PM
NE OK
Well the deer have officially gone nocturnal here..
Only group I saw yesterday was a half dozen 200 yards the other side of a tree line.
They be layin low...
Here as well
Sent from my SM-G955U using Tapatalk
Come to my house and you can shoot them off the front porch. Most I ever counted was 13; see them almost every night. I'm sure they will disappear once you start shooting though; and the police will show up in short order:
95D1106D-B410-450D-88DF-95CC108FA502.jpeg F0354333-D19C-4F55-93BF-DB0FD7B2A864.jpeg
MACHINE
6:18 PM
Broken Bow, Oklahoma
Workshop
5:18 PM
Nixa, Mo.
How did the tree work go yesterday?
A lot of tree tops down there. Easy access when it's dry but the top inch was slick as snot. My truck wouldn't do it so we cut for 2-3 hours then came home and got Goldies truck.
4 wheel low back right up to it.
1 load yesterday and 1 just now and I'm worn out. I'll spend the rest of the day splitting and stacking.
5:18 PM
Sounds like you need a winch and an LSD for your 2wd rigs.
MACHINE
6:18 PM
Worked on the Husky 445 all day and no closer to solving it’s problem.
Acts like it’s starving for fuel on a long cut. Dies but restarts easily.
[emoji90]
Where is the tank vent on this POS?
I rework them to a stihl style ,
Works much better
Hedgerow
5:18 PM
[emoji90]
Don’t feel bad Carl..
I had to replace a fuel line and carb on an ms271 today...
what a dumb setup..
Ran good with new carb though.
Locust Cutter
Air Force Redneck
5:18 PM
KS
Ummm,
I need to put my 2wd rigs on LSD?
Won't that make them hard to drive?
Not really unless you drive it like a hooligan. Now, a full locker can make for interesting turning and some other things, but a good LSD acts as one wheel drive until slippage occurs, then you have actual 2wd. It unlocks again once both wheels are tuning at the same speed for a specified amount of time, that varies by manufacturer.
On another note, Dad and I busted up a bit over a cord Saturday and got it stacked, and I got the area cleaned up with the tractor and scraper after that. It's nice to get crap done, and get the mess cleaned up, before making further messes! I should be heading East soon to clean up some Hedge and other trees as part of a fence repair effort in a buddy's pasture in between Leon and Beaumont KS. About 350 yards of 5 wire to remove and replace, and several trees that have to come out for that. I'm figuring that I'll have somewhere between 2-6 dump loads based on what he's told me. I may borrow a friend's GN trailer to make a bigger haul. We'll see.
Hedgerow
5:18 PM
I think Steve was referring to LSD like the hallucinogenic stuff that twisted the minds of the 1960’s generation.
Workshop
5:18 PM
Nixa, Mo.
Nailed it!!
:aaaaa::aaaaa::aaaaa:
While, technically, I'm not really a part of the "Hippy" generation (I was in the 6th grade in 1968) I was somewhat influenced by it.
Not by drugs, though.
I understand locker rearends. I've just never heard them named after a hallucenagenic drug before. Perhaps I need to update to modern terminology. But then, I come from the time of knobs and levers.
I miss knobs and levers.
MACHINE
6:18 PM
Pic?
Line with gudgeon screw? [emoji848]
We have drill bits. [emoji106]
Been thinking that over.
Don't have one around, on the 365 i drilled it out , installed vent line, rand vent up by air filter, sthil vents are cheap and work , Husqvarna vents are hard to get to and fail much more
67L36Driver
5:18 PM
what a dumb setup..
The fellows at Jack Horners cautioned me to avoid 271. Because they are a PITA.
Stihl models ending with a 1 in general.
I did refurb a 270 once. It was different. [emoji19]
Hedgerow
5:18 PM
Had to drop the tank away from the handle and dismantle 2 mounting springs to get under the platform to see how the fuel line even routed to the tank..
I pity the bastard that has to replace the line inside the tank.. “yes, there’s 2 fuel lines” yuk..
plcnut
Jesus is LORD
5:18 PM
Mansfield, Missouri
My 94 chevy 1 ton has a [EDIT] 14 bolt rear in it (with limited slip).
A few years ago it was giving some issue with catching while turning on pavemen.
I was grossing around 18k and took a turn onto an on ramp, and it popped and locked up. I was able to go in reverse and it broke free.
It made some ugly noises but I managed to get it home without a tow.
The carrier was broke entirely in half.
My brother came and set up a new carrier, ring, and pinion in my driveway and it has never given any trouble since. No noise either.
