MACHINE
5:23 AM
Broken Bow, Oklahoma
It’s just an aerosol copper spray coating for head gaskets and such. Works really well for sealing imperfections. Like if those gaskets came off clean you could spray them then go back together no problems.
I use the liquid and brush
Sent from my SM-G955U using Tapatalk
countryhog
BTDT
4:23 AM
NW Arkansas
Also comes in a can with a brush attached to lid. Least it used to. Great stuff for gaskets
JimBear
4:23 AM
IA
Any of you old timers know what this:
I am curious are the numbers on the dial degrees or tenths of an inch? There appears to be 10 teeth per every 10number increment. Does it spin freely? Is that little bolt/screw head a set screw or maybe for holding a cover on to keep debris out of the worm gear/teeth? Is there any spring type mechanism under the dial ? I would guess some type of timing or synchronization tool. Was this the surprise inside a box of Cracker Jack??
Jetmd
4:23 AM
Smithville, MO..Born in Iowa by the grace of God
The pointed end spins freely and the worm gear does turn the dial.
The straight blade machine screw can be loosened to rotate the small pointer on the dial face.
That's all I got. This was given to me along with an assortment of other antique tools by my Dad.
Maybe take it with me next time I go visit see if he has any idea?
sawnami
5:23 AM
Springfield
Machinist's tachometer. It should have a rubber tip on the end. You put it in the center of a spinning shaft and time it for a minute to see how many revolutions it registers.
Sent from my SM-T900 using Tapatalk
Hinerman
4:23 AM
NE OK
Of course it is. That's a wrap. I like the way Louis thinks though :)
Good Morning everybody.
plcnut
Jesus is LORD
4:23 AM
Mansfield, Missouri
I have one of those!
Mine is a Starret.
They were used to measure speeds in a machine shop to calculate feed speeds on a lathe, etc.
You would use a stopwatch along with the dial to get your surface speed.
Workshop
4:23 AM
Nixa, Mo.
Waiting on Goldie to get home. Then we're headed to Hootin Holler. Primary objective this weekend is to get the well pump installed and operating and bring back a water sample for testing. Plus try to get about 30 other things done.
JimBear
4:23 AM
IA
I lost my billfold yesterday hauling in hay, didn’t figure I’d every find it after driving thru CRP that was 2’-4’ tall & up & down the road but apparently the sun does shine on a dogs arse every once in awhile. Lol.
67L36Driver
4:23 AM
Two of us needs a new rubber tip.
No timer needed, turns either direction.
Was in my Dad’s tools.
