plcnut
Jesus is LORD
- 12:20 PM
- Feb 20, 2016
- Mansfield, Missouri
Looks like an Onan there too...View attachment 243463
Bringing it home.
Bringing it home.
None of those engines laying around & no go- karts laying around either. I’ve never had one. I told Dad I wanted a go kart when I was about 10, I got a 2N Ford-Ferguson with a 3point platform carry-all & a 2 bottom plow, told to I could plow the garden, pick up trash along the roads, sticks & rocks in the fields. He was less than impressed when I cut some donuts in the yard with it.That would be a neat one to play with! If you got an extra one laying around I’ll fab the karts together!
I bought it as spare parts for my other two, but if I run across another engine for cheap I may just bring it back to life.It's actually a kt17 kohler. Series 1 that's toasted.
Do they fit the old Onan generators?It's actually a kt17 kohler. Series 1 that's toasted.
The Onan used a special crankshaft and mount that prevents people from replacing them easily.
I have a Miller welder with an Onan, and would like to find an engine for it that is not obsolete.[/QUOTE
My understanding, on these, is that the kt17 kohler series 1 they came with had problems with the oiling system. Technically it was a pressurized system but it was only about 5psi. The rods were drip lubed from left over oil to the crank shaft. As long as you kept it level There wasn't any real problems with the rods getting enough oil. But anytime you cut on a hill, the rods were starved and they'd get tossed through the block. The series 2 engines ran about 50psi and had an oil filter too. Problem solved.
Deere had a warranty program that used an Onan as the replacement. But they required a special kit to mount them and connect the drive shaft to the flywheel side of the engine. The kohler magnum 18 is a direct drop in. (That's what I used as a replacement engine) The switch has to be wired different because the original engines were battery ignition and the replacements are mag ignition.
Vangaurd v twins are a popular replacement in them, too. There are kits available to install them.
I picked up a 6500 onan generator a couple of weeks ago for $140. They're out there still.Do they fit the old Onan generators?
Guess he should have “left a deposit in the bank”...Onan was a biblical character killed by god for ‘pulling out’ in order to avoid offspring.
(I asked Siri.)
Why did they name a company such always puzzled me. [emoji848]
Looks like I may be the proud owner of a wood mizer wide cut band saw..
Pics to follow. In a couple days.
Good morning!
I've got a friend that has an estate sale company that's having a big one this weekend. A lot of vintage guns and gun parts. Also quite a bit of metal working equipment.
https://www.estatesales.net/MO/Ozark/65721/2528616
Morning midlanders!
Forecast is for warm to hot for the next week.
Skin our knuckles on the Ford some more. [emoji2955]
Is your tetanus shot up to date?![]()
