67L36Driver
11:56 PM
Dirty Old Blue:
Clean Old Blue:
Paint is shot and needs some glass repair. Also needs seats, carpet and top.
8" C3 rims on the back end.
Build date Friday Sept. 16, 1966. 932nd one built, 393rd convertible.
There was a time I didn't have a pickup.
moparnut88
12:56 AM
US
Got some more info on the old skidder it’s a c4 tree farmer. Anybody know anything about them. This one has a rebuilt tranny ready to go back in it. Winch works and tires are good. Supposed to run good. All I know so far.
67L36Driver
11:56 PM
Rate my 'wiring' job:
Two gallon can filled faster than anticipated and ran over.
Got the nasty pumped out.
What little is left of the build sheet.
mdavlee
Hillbilly grinder
12:56 AM
TN
More than likely a Detroit in it. I seen a few in my area and some guys said they held a hill better than the Deere offerings at the time. But not quite a timber jack of the same time.
mdavlee
Hillbilly grinder
12:56 AM
TN
You know which series it was?
mdavlee
Hillbilly grinder
12:56 AM
TN
No I don’t. I’ll have to check when I go look at it. Any idea how much it should be worth?
$3-8k is what I’ve seen them around home depending on which series and how good the pins and hoses are. That stuff will add up to big money quickly as I’m sure you know.
moparnut88
12:56 AM
US
Yes I know all too well. Last weekend off had 2 hoses blow on the 580 backhoe and 2 on the 450 dozer in the same day. Every hose 3/4”+ is a$100 real easy if they are special fittings.
Cat 525
11:56 PM
Central Kansas
Know a couple guys that used to run em! All I know is they are easy to get jobbinhouse parts for. Can't do that with a Cat or Deere so much.
Locust Cutter
Air Force Redneck
11:56 PM
KS
Evening All! Got some mowing done, haled a load of manure for a friend of a friend, cleaned, greased and lubed the dump trailer (man the joins pack with s-word!!), and rigged a 55gal plastic barrel to haul water around for the boss to tend to her randomly placed flowers. It was a gorgeous day! I'm getting excited now, waiting on that triumph to get here. 140 cubic inches of engine in a bike is pretty entertaining.
67L36Driver
11:56 PM
Ordered an evilbay fuel line for the Jonsered 630 on the 24th from yourpartsdirect13 in Lenexa, Ks.
They used DHL to ship.
It went to St. Louis and has been there since.[emoji2955]
Lenexa is 62 miles from Joetown.
I could have walked there and back. [emoji2959]
Junkyard
Can’t have too many saws
11:56 PM
Claremore, OK
Any of you heavy equipment men have a truck/tractor rim you want to sell?
I have a bunch of them. You’re welcome to one. If memory serves I have one with a slightly bent bead that’s no good anymore. Either way I have plenty!
