MACHINE
12:41 PM
Broken Bow, Oklahoma
LMAO
Sent from my SM-G955U using Tapatalk
ArSawMechanic
Active OPE Member
11:41 AM
Pea Ridge AR
Hi Brandon. Good to hear from you.
Are you taking good care of that John Deere saw for me? [emoji4]
Sent from my SM-T900 using Tapatalk
Well, you see... not so much on the John Deere. A garage fire back in 2014 pretty much wiped out my entire collection of saws. I had all of my prizes on upper shelves, junkers on the floor. So when it was said & done, the prized ones melted & or burnt up, and the junk pile was almost unscathed. Who'd have thunk that heat rises? Another lesson learned that day: No more plastic trash cans in the garage!
Sent from my SM-G960U using Tapatalk
sawnami
12:41 PM
Springfield
Oh my! A pristine John Deere 66SV twin meets a tragic fate!
Hope you were OK other than the saws.
TALLGUY
11:41 AM
VERMILLION SD
Morning midlanders!!
Evilbay seller refunded my money on the “028” oil pump gears. [emoji106]
Only problem left is the choke won’t stay set with the new air filter. [emoji90]
Carl
I had a 028 the other day the choke would not stay set. New air filter. I swapped the choke out of a old filter. Fixed it. Both were oem.
67L36Driver
11:41 AM
Carl
Went back to Jack Horners and John showed me where to grind back the AF choke lever so it would work.
Fixed! [emoji16]
Junkyard
Can’t have too many saws
11:41 AM
Claremore, OK
T
Use a Farmertec MS390 engine in those. [emoji106] Ditch the Stihl self tapping screws and use the 6mm machine screws provided.
Thank me later.
[emoji16]
That’s my plan. Ordered a 390 setup for the 310 and a complete bottom end for the 290.
67L36Driver
11:41 AM
Carl
Look carefully at the cam part of the new filter choke flap and one can see where they added material to the original mold. Dremel it back to that mold seam.
John told me Stihl had put out a bulletin to that effect.
Hedgerow
11:41 AM
They run even better without an air filter at all..
