Honest John
- 7:05 AM
- Jan 10, 2016
I think you're right. How bad do you want it ?![]()
Nice score!!...and welcome aboard to the site.Hey all, new here. I hav't seen much on the Homelite 750. I understand that it's 113cc i believe. I found these at an auction. One is seized up. The other i spent all day sunday tinkering with and got running. Its definitely an impressive machine.
You will want to check the boot on those. A bad boot can ruin a saw. (Air leak lean running)Hey all, new here. I hav't seen much on the Homelite 750. I understand that it's 113cc i believe. I found these at an auction. One is seized up. The other i spent all day sunday tinkering with and got running. Its definitely an impressive machine.
I brought home an other super ez so my first one would not be lonely. It is newer with the plastic recoil cover. I have not checked to see if it has blue solid state ignition. I had to replace the clutch cover due to hole eaten through by loose clutch screw.View attachment 66514View attachment 66514 View attachment 66516
A IPL for your saw http://www.leonschainsawpartsandrep...4018_cs-50_cs-5020_chainsaw_ipl_18952-b_2.pdfgot this old saw for free its runs and oils just needs a few parts changed its from the early 90's? 49.2cc 11.75 lbs according to acres it has spring av and no chain brake its a nice saw but i can't find a lot of info.
did homelite make this or someone else?
It's supposed to have a brake, looks like yours is missing.got this old saw for free its runs and oils just needs a few parts changed its from the early 90's? 49.2cc 11.75 lbs according to acres it has spring av and no chain brake its a nice saw but i can't find a lot of info.
