- 2:30 PM
- Jan 17, 2016
- cape cod ma.
Points/condenser?
Sent from my XT1585 using Tapatalk
Yup, That's exactly where i would go.
Points/condenser?
Not sure. You have an inline spark tester?Thanks. Gonna check them. Guess I was wanting a miracle, don't hafta take it down response. Got any idea what the capacitance should be on the condenser?
my super xl auto has a leaking seal on the clutch side and i noticed the seal is NLA would you guys know if a national 253747 would fit?
i would greatly appreciate the help.
what does it cross to.It won't. That seal will fit on the flywheel side. You're looking for a 58308 A or B.
I may have one that will fit better than the sub I'm using now but I haven't ordered one yet to try.
The 58308 A and B are available from several suppliers at present for under $10 plus shipping.
The points are good and gapped right. Removed the coil assembly and discovered the pin in the coil that the high tension lead screws in to is broken off. The coating on the coil is squishy too. Guess it got hot, eh?thanks guys
