HOMELITE Homelite Thread
countryhog
BTDT
1:33 PM
NW Arkansas
My xl2 is the double trigger so handle cover is different. See pix below. Two sets of hooks to mount handle in slot. The hook on the right is the one I broke. I super glued it but not confident it will remain attached when I install it; we’ll see when I put everything back together. Apparently yer sposed to nudge the hook, very gently, with a screwdriver through the hole in the end of the handle
Sagebrush33
2:33 PM
Upstater
I believe I have 2 of these tucked away somewhere. One my be a bit more of a non runner. They are very interesting saws.
davidwyby
Rural desert logging
11:33 AM
Extreme Southeast CA
My double trigger saw was my gpa’s...
the single one is parts for it if needed
Dream
2:33 PM
Elberton, GA
Whats a Homelite 5-30?
Think its a gear drive. Seized.
Has B&C
Dream
2:33 PM
Elberton, GA
5-30 is a belt drive 114cc I believe. Both that and the 944 are strong saws when running. Sometimes freeing them is easy.
Thought it was a gear drive.
Guess that was the belt housing.
As long as it stuck from sitting, it wouldnt be a big deal.
Dream
2:33 PM
Elberton, GA
Dream
2:33 PM
Elberton, GA
@Dream your 5-30 is not a 5-30, It is a 26 LCS, The second model Homelite produced.
The 944 is also not a 944 as 944's are a antivibe saw and should look like @fossil 922.
Ok. I'm doing this long distance, as the guy that called me about them is in Maine and doesnt know much about saws.
He gave me the 5-30 and VI944 from what he saw on the tags. Not sure where he got the 5-30 markings, bit the VI 944 came from the id tag. Not saying it wasnt off another saw.
mirage
12:33 PM
idaho
Can anyone help with a XL12 with low compression. I would buy a little red barn kit but it has a lot of negative comments. It has about 85 PSI . Will run but not good.
