- 3:35 PM
- Jan 24, 2018
- Extreme Southeast CA
Score
Yep! Could u imagine:No sir. Too many wires and computers. I like simple.
I like that very much. 2100 and 2150 worked on every size engine, just change jets.Yep! Could u imagine:
A permanent gear set for cam timing? No tearing down the entire fkn engine for a dual overhead cam timing belt or timing chain.
A $280, 2100 carburetor and fuel pump right on the side of the block? A carburetor so simple, u can do a jet change in 2 minutes without spilling a drop of gas. 12 annular fuel passages in the venturi cluster that atomize fuel just as good as these silly throttle body injection kits full of cheap chinese components?
It's actually a Ford chassis, but correct. My brother has a 68 F250 2wd truck that is donating the body for that build.Heck yeah woodslasher! That square body drivetrain going under a 67-72?
Just like the ford highboy trucks, on the older chevy, closed knuckle Dana 44's are obsolete garbage.
Keep yer eyes peeled for an m1031 cucv. 4:56 gears, detroit locker, double overload rear springs, traclok front limited slip, NP205 with pto, hydroboost brakes.
67-72: The fkn vintage muscle car of wood trucks. Interiors are just as nice as the exterior.
3.0 Diesel for not the win..
