Fuel cans suck...
PA Dan
1:59 PM
White Oak PA
Are there any fuel cans out there that are any good? I absolutely hate the styles available today! The expand and contract and if you go to fill a saw and don't relieve the pressure look out! So has anyone found some good ones? What are you using? I left this one out over night and it got into the 40's!
USMC615
Fapper Fi
1:59 PM
Mid-Georgia
I been running the same dozen or better, old school, non-EPA, 2.5-5-10 gal plastic and metal gas cans with rear vents for years. I guess most folks use those Jill's Jugs or whatever they are, seen some talk about them anyhow on different threads. Don't know if they'll eliminate the expansion/contraction problem or not, but might be worth a try.
CJ Brown
1:59 PM
Belleville, Ontario, Canada
First thing I do on cans like that is drill a hole in the top/rear portion of the handle and install a big 1" long wood screw that I can remove or install with my fingers. You can attach the screw to the handle with a piece of thin wire or string if you are afraid of losing it when you are pouring.
One day an engineer decided to build a better gas can, and from that day forth they have been garbage. You can't even buy a proper spout for them anymore.
USMC615
Fapper Fi
1:59 PM
Mid-Georgia
I bought a couple of 5-gal kerosene cans last year that were the new-fangled EPA chit. Immediately walked back over to the aisle and purchased the conversion, non-EPA spouts, got'em home, replaced the spouts, drilled and reamed a .490 vent hole in the top rear, snapped in and sealed in place the 1/2" vent that came with the conversion spouts. Sent the chit EPA spouts to the landfill with the trash.
USMC615
Fapper Fi
1:59 PM
Mid-Georgia
No conversion kits up here - can't be undoing .gov's handywork you see. However, I am going shopping on the Bay and see what I can find.
If you can't find any for your mfg of can, let me know. Local hardware stores here have them by the dozens for various mfg's cans.
Hinerman
12:59 PM
NE OK
Love my No Spill Jill.
Another vote for No-Spill.
However, PA Dan, they do expand and contract, and you need to relieve the pressure or they will spray fuel everywhere. So don't purchase them thinking they won't.
Homemade
1:59 PM
Wisconsin
moparnut88
1:59 PM
US
The best idea to fix the new plastic EPA jugs I've seen a is drill a 1/2" hole in the rear of them then fish a rubber valve stem thru it and install the valve stem and leave the valve core out and open the valve cap to vent as needed.
Adirondackstihl
1:59 PM
Upstate NY
That's a good idea!
exSW
'Cause Thomas is a poopyhead
1:59 PM
United States
1:59 PM
I did the same to my plastic gas cans. I drilled the hole and installed a short rubber valve stem with guts removed. Works perfectly. But I also have a 5 gallon plastic Sunoco Race Fuel can. Paid $33 for it at my local race track. And I have a 2 gallon no spill can that works well too.
