Firewood thread!!! Let's see what you got!!!!
bigbadbob
8:33 AM
Interior BC Canada
On the backroad drive to my cabin I found a nice sized birch dropped by a beaver,, so I used my 2071W to cut it. 20 inch bar is sure nice on that saw
Biggest birch I have seen here. On the stump if you zoom in is a spike on the right hand side,, the beaver almost got to chew it,, I did find another spike with my saw,, probably from a "No Firewood Cutting " sign.birch1.jpg birch2.jpg birch4.jpg
Locust Cutter
Air Force Redneck
10:33 AM
KS
I'm truly blessed to have the dump trailer that I got off of a friend for a deal I couldn't turn down. If/When I buy a new one (in 5-10) it WILL be a GN, and may opt for the gas engine power pack for dumping, as you can run it all day with no battery to run down, or extra charging circuit to run on the truck (beyond the small factory one). my 7x14 Diamond C has been amazing, and I'll only sell it if/when a GN replaces it, as they tow far better. Mine tows well for a bumper pull, but there's no beating a GN or a 5th Wheel, when real weight is involved...
MG2186
10:33 AM
Summer,IA
Yea dont know how we got a long as we did for as long as we did without it. They sure are handy. We have battery cables with snow plow connections in the boxes of all our trucks for wenches and the dump trailer. Those batteries on the trailer can be a pain in the ass. Seems like they’re always dead or not charging. This trailer needs heavier axles on it, we want to find a set of 10k dually axles for it. If I haul much over 8-8-1/2 ton of rock in it I start blowing tires
Hinerman
10:33 AM
NE OK
I like the idea of a GN dump trailer or even a bumper pull dump trailer, but I have no way to load one. I load by hand and dump trailer sides are too high; even the floor is too high on most of them. You can get one with a drop axle but that is more expense and then you have trouble dumping.
Locust Cutter
Air Force Redneck
10:33 AM
KS
I thought about going heavier, but if I do, I'll need a 4500-5500 series truck to be comfortable with that. I've pulled 26K with my F-350 once, and won't do that again. 20K is about as far as I want to go, and 18K feels a lot better, especially given the amount of highway travel I do, and given how sue happy people have gotten, coupled with KDOT enforcement getting worse every year in the name of money... If it was just farm hauling, I wouldn't think twice. And, I got a 4 year old trailer with VERY little wear for about$1500 not counting the new tires and battery... I know what my buddy bought it for new (8K-ish), and that was a deal I couldn't turn down!
I definitely understand where you're at Thomas. If I didn't have my tractor, the dump trailer wouldn't be worth it, and I'd still be using the dolly. It's all puzzle pieces. Unfortunately, with the screws in my back and the other 3 discs going south, I'm not going to quit doing this, but I've had to become more careful and methodical in how I do it...
MG2186
10:33 AM
Summer,IA
That’s what we have is F-350’s. I’ve hauled way more than I’m supposed to a lot and have been real fortunate not to get pulled over. Believe me if I could keep tires on it I’d be hauling more, the quarry is only 7 miles away. I had 14 ton in it the first time I used it, blew 2 tires and tweaked the axle in the process, that was DUMB! On my part. Pulling it doesn’t bother me but like u say too many idiots and stopping for them is the problem!
No way would I load that with by hand with wood, my goal is to only handle the wood as little as possible, we use skid loaders and loader tractors as much as possible so Thomas I know what you’re talking about.
I don’t care for bumper pull trailers other than for small lighter loads, hard to get them to pull descent it seems
Locust Cutter
Air Force Redneck
10:33 AM
KS
They can tow well, but when it's 12K or more, I prefer GN or 5th Wheel. Plus you can jack-knife if needed. 20170825_152251.jpg
This is my Tow pig...
This was the too' much load (about 60 tops)...
And that's my Diamond C attached to Dad's F-350, with my tractor in the background and the buddy beside the trailer who I got them both from. With the empty weight, I basically have a 5K useful load before I'm testing the axles and tires... I'd like to try a GN, 19.5 rimmed version of this eventually with Hyd Disc brakes, and torsion axles at a 16-18K rating. That would be about perfect. More than that would be CDL territory.
stihl livin
Do the Dallas
10:33 AM
Upper Midwest
They can tow well, but when it's 12K or more, I prefer GN or 5th Wheel. Plus you can jack-knife if needed. View attachment 270086
What load range are those tires on the trailer. They look like E and you can get 16” in load range G or H. Hell I got G in 15 on my car/skid trailer. Well worth the money
Locust Cutter
Air Force Redneck
10:33 AM
KS
They're F or G I believe. I'll have to look, but they're a step or two beyond E's. When I put them on the cost difference wasn't a lot, so I said the hell with it. They might actually be H's if there isn't an F...
11:33 AM
I wasn't certain the old Fergy would pull that log up closer to the splitter .Log tongs are really too small I could only lift it about 1 inch but it was enough to put weight on the rear tires so they didn't spin .The log was in the neighborhood of 3500 pounds
11:33 AM
Firewood ,saws are involved .This was just a test to which old Swede gets the brass ring . Husqvarna 2100 CD vs . McCulloch version of a P-100 Partner .Both 99 cc both with 20" bars and freshly filed chains shag bark hickory about 21 ".
It was pretty much a dead heat quite frankly .Both have oodles of power Both set just a tad rich on purpose .
11:33 AM
This is part of the first log ,a 20 footer .As soon as I get the second log split I'll break out the big guns ,avatar saw 2100S Homelite ,Mac 125 and Stihl 084 .These will all be with long bars because I have no short bars for them .
RI Chevy
11:33 AM
earth
Nice! What kind of tree? One heck of a load on that truck
Cobus
“It’s just work”
8:33 AM
Oregon
For the most part I cut lodgepole. That was 3 cord total. Actually a little over because it was heaped. But... I went across the scales at 18k lbs and that wood was all dry and ready to burn! That was my 42nd cord for the year. Hopefully I can beat that this year.
