Fin damage... To run or not to run...
Canadian farm boy
“Normal” people scare me.
9:05 AM
Ontario, Canada
I'd probably run it. Maybe run it a little fat on the tune or try a higher octane fuel to help keep it a few degrees cooler. Opening up the muffler a bit will also help get rid of unnecessary heat.
P.M.P.
Stiff Member
9:05 AM
Michigan
Id run it maybe do a little grinding so it could breathe let the heat escape out the exhaust port.Anyone one ever try to jb weld fins back on?Or form your own fins?
Canadian farm boy
9:05 AM
Ontario, Canada
I'm sure I read about somebody around here repairing cooling fins and repairing muffler flanges. I can't remember who it was but I'm pretty sure @skippy would know who it was
SixGun
9:05 AM
Hackettstown NJ
I've had tig welding done on a cylinder intake and it turned out beautiful. Never did fins yet but seems doable
beaglebriar
The Peanut Gallery
9:05 AM
Warren Center, PA
I saw one that someone did over on AS that looked real nice. Actually got me thinking when I do overhaul the 385 I may take the old cylinder to work and try welding it up.
jockeydeuce
6:05 AM
BC, Canada
That cylinder will probably be fine forever....I have had saws on my bench that customers have been running for extended periods with the fins so plugged with pitch and gunk that the cylinder was pretty much a solid slug (Logging saws). Not only was there no air flow, but the cylinder was insulated!:eek: .....If kept clean, there's no way a cylinder like that won't last.
Black Dog Chainsaw
Mak-Crazy
9:05 AM
Indianola, IA
X2 on the welding. A cheaper option might be to use some aluminum brazing rod. It just needs enough contact to transfer heat. Pretty doesn't matter at this point, and it's not like they need to be real solid b/c they aren't structural.
Mark71gtx
9:05 AM
Fuquay Varina, NC
What filler metal and Welding process do you use when repairing cylinders? The welds look clean, so I am assuming high frequency TIG? I normally weld stainless or carbon. The aluminum filler material is not something I am familiar with. Thanks!
