Exhaust theory
Thesandman
7:39 AM
Mid michigan
On my çs4910 I measured the ex port, muffler flange, muffler exit hole and exit hole cover. All in square inches@ .43, .68, .38 and cover @.3. after opening it up alot. What am I looking for? No restrictions? I expect to make ex port much larger eventually but for now what is common practice?
Ketchup
Epoxy member
5:39 AM
Colorado
Not sure for 4910, but the ballpark for ported saws is 80-100% of exhaust port area at the muffler outlet. No restrictions in between. Infinite ways to skin that cat though.
Funky sawman
Pony Power
4:39 AM
North idaho
I do 120 percent larger on the outlet port, because I take into account the restriction that a usfs approved spark screen makes. Never had issues with power loss or idle issues, but much bigger will cause issues. I talking about stock saws here
Ketchup
Epoxy member
5:39 AM
Colorado
Good point. Screens restrict the outlet a lot. 120% with a screen has worked really well on several of my saws. And they help with noise.
Also, multiple ports won’t flow as much as a single port of the same total size.
7:39 AM
Factory screen flows about 30% I believe. You’ll notice there is always some distance between the oem exit hole and the screen. So if using the factory screen, there’s not much to be had from opening the hole much more than 1/3 the size of the screen
