Echo Cs 730 hybrid build.
Red97
11:59 AM
MI
This is the saw Echo should make.
Started with the cs 590,600,620 chassis.
This one is a 600.
Made a .380" spacer with a flange to fit the case, and a counterbore to fit the jug extension.
Red97
11:59 AM
MI
Used a 50mm husky 268 window piston.
Had to cut approx. 040 out of the band to fit. With keeping the numbers close.
Jug is a 50mm echo 670. Center fed quad port.
Red97
11:59 AM
MI
Made a spacer/adaptor flange to get the exhaust on the correct angle. And allow the use of a wider flange for the muffler. Which you can see took a bit of doing.
Red97
11:59 AM
MI
Made the flange, and the tube to start. Cut, weld, fold, bend till it fit where/how I wanted. Open up the side and cap it off with one of my medium reflectors. Finish off with high temp paint. Ain't super Purdy, but will do the job.
Red97
11:59 AM
MI
Numbers with the 268 piston.
In 75.5
Ex 101
Tr 115
Widened the exhaust, and lowered the floor about .070 so the piston was above the floor at bdc. Matched the intake port to the 600 boot.
Opened up the lower tunnels to match the window in the piston.
Red97
11:59 AM
MI
Intake boot needed a .080 spacer. That got clamped on on with motoseal for insurance. Little bit of clean up and assembly. Comp reading is fresh after assembly. No run time.
Red97
11:59 AM
MI
Ok, all together still need to mod the carb. Omit the bypass nozzle, so I can tune it normally. Still has the 13.5k limited coil.
So what was the point of this??? And why cs 730?
Well thus series has a long stroke small bore stock. 45mm bore 37.6 stroke 59.8cc
Now 50mm bore 37.6 stroke 73.8cc same package :)
Numbers aren't ideal imo, but I needed a baseline.
I have about .010-15 before the top of the piston ring gets into the ring of death at the top of the jug. I would really love to get the transfers up round 118-9 but would have to drop the jug .030-40 the piston ring is starting to get close to the snagging point at that depth.
Red97
11:59 AM
MI
You have some pretty cool stuff going on in your shop...
Thank you. Plenty to get side tracked with for sure.
I bet with that spacer and exhaust so far away she will have some torque.looks good.
Thank you.
I hope so. A ton of variables with this critter for sure.
Hda carb, limited coil, odd timing numbers. Where to go where to go. Lol
Cracker Boy
Fl cracker
11:59 AM
Florida
Thank you.
You are the echo whisperer lol.andy wellman aka westhouse saws builds a spacer on allmost all his builds calls it a grunt gasket.looking good.
Red97
11:59 AM
MI
Very cool. Love these crazy builds. Can't wait to see it cutting.
Thank you. Have some smaller test logs leftover from the 50cc saws. It's getting put in wood tomorrow...
The spacer was mainly to correct the angle, while trying to attach to the stock muffler. That didn't work out, so super muffler mod it is.
If I were to do it over, I would have formed a horn shape into the can vs the oversize square. But to be honest the square was way easier, and somewhat resembles the stock deflector setup.
Red97
11:59 AM
MI
Forgot to mention the biggest part for this conversion..
The wrist pin bearing. The 599,600,620 uses a 11mm pin with the 268 is 12mm. Found a conversion bearing fits the rod, and 12mm pin prefect. Same bearing used to convert the 510 echo to the husky piston as well.
Red97
11:59 AM
MI
I was wondering who this was that was showing this build in the chainsaw repair group :cool:. Very nice and thinking out of the box. :b1:
That be me. Thank you.
Nice work Joe.
Thank you. It feels really sporty. Need to try some longer bar buried cuts. Get the ring seated in before I tear it back down.
