Echo cs 490 porting
10:45 AM
Finally home.
Hoping to open the 490 carb today.
If the RPMs don't jump, I may have to pull my jug and relieve my bottom like Red97 did.
Then hopefully a few cuts with the 20" and a try to fit the 14" low pro bar on the saw.
Red97
10:45 AM
MI
Finally home.
Keep us posted.
Only other minor thing I would try would be retarding the timing just a bit, before ya pull the jug off.
The lo pro may work pretty well on these saws...
Red97
10:45 AM
MI
Just watched my vid again.
Looks wayyyyyyyyy fat and slow.
I'm hoping the carb fixes that.
I should be back home Tuesday. Hopefully have time to mess with the other carbs.
So what is your plan drf255?
Are you going to try and grind the venturi out to the max? Thin the shafts/ screws? Or take a little at a time?
Don't forget after you get your carb modded to test with and without the air filter.
10:45 AM
My understanding is that the max diameter we have to work with is 16mm Joe.
I'm gonna remove the choke plate and shaft. Open the Venturi to 15mm and thing the shaft on the choke and throttle plates.
If the AF is really bad, I'm gonna cut out the fleece and add some metal mesh over it.
If I can get 14,500 out of it, I'd be happy. (Yeah right, who am I kidding-lol)
Red97
10:45 AM
MI
Sounds like a great plan.
14,500 would be awesome, leave it set at 14,450 :)
I think picking up the extra 1000-1500 rpm would make these saws limbing machines. Being quite light and nimble with 18-20" bars.
bikemike
9:45 AM
Cottage grove mn
Finally home.
When you pull the carb send a good pic of what the venturi looks like from the choke side of carb
Red97
10:45 AM
MI
Nah,
Has to some ridiculous obscure OCD amount. 30% will not do when it comes to saws.
Lol, I have good wifi here at the apartment.
Just checked my stock vs ported times vs rs chain
Stock 2 cut avg= 23.5
Ported 2 cut avg (stock chain)= 15.5
+34.04% faster
Stock= 23.5
Ported RS chain= 14
+ 40.43%
I am very happy with those gains. But still wanna find more.....
bikemike
9:45 AM
Cottage grove mn
Well if they don't want to pull more rpm then keep the compression up and use a bigger rim
Red97
10:45 AM
MI
Do you have any close up pictures of the ones you have modified?
10:45 AM
+34.04% faster
Stock= 23.5
Ported RS chain= 14
+ 40.43%
I'd be happy too. Quite respectable.
I never did any stock cuts. Pertly cause I wanted to dive right in, and mostly cause I wanted to finally work on a brand new saw.
We should come up with some readily available constant for cutting. Like a 6x6 yellow pine railroad tie.
I know it will cost a bit, and you can't burn the wood, but it would give us a constant. Maybe even 2 0r 4 strapped together.
Might be a way to get better comparisons of gains on the web.
