I guess you got that 670, huh?
What a wacko that seller was.
Isn't it one clean saw?
Yessir, very clean.
Thank you for fetching it.
No doubt less compression would help but I'd open the chamber instead of raising the exhaust.
What's the port timing?
It has no ignition advance?
I've seen a bigger carb not help at all,it can only take in as much as it can get out.
What it at with a oem piston?Piston swap, likely cut through the top..
Very small exhaust, for 66cc imo, just thinking raising it will help more than hurt, possibly stretch the bd in the 24/5 range. Feel the tunnels are a little tight, a bit more pressure may be a good thin here..
Current numbers are 101, 123, 81
Stock timing key
Think you are correct on the bigger carb, just what I had to rebuild at the time. Have a good small carb to try now.
Jus feel it is missing something.
A 064 or 066 with a oem piston can't be much wider than 60%
Sounds like it's held back,probably the compression.
Ignition advance could be a big gain
020 is good
I don't think you will loose that much compression but the extra bd could help.
At bdc is the crown still in the uppers?
Might not be opening them much.
Joe....
You have excellent machining skills buddy.
If you send me a 670 jug that cleaned up, I'll slather 4043 all around that exhaust port for ya. You can resurface it and move the holes.
Voilá!
One Echovarna with really wide exhaust port, coming up.Hmm, might have to take you up on that on one of these..
Maybe the jug that is gonna get the pipe.
Thank you for the offer.
Looks really good Joe. Can't wait to see the video.
I missed the radius the first time I looked at the pictures. Nice touch.
I have a 670 jug with a lot of transfer, it should clean up. You're welcome to it if you want it. It's just taking up room here.Hmm, might have to take you up on that on one of these..
