Clean saw. Really similar to the 670 except Air filter, Chain brake, cover, front tensioner, and color. are the main visible ques.
Small ex port, but look at the dropped floor...
This one will clean up real nice.
Might dig back into this one after a std port job. Be really easy to adapt a large carb/boot, not planning to at this time.
This has me kind of baffled. No base gasket/ sealer at all.. nothing appears to be touched... based on the corrosion on the jug bolts. Wonder if it was like that since new? Still had plenty of comp to run and a new tygon fuel line.
Nice little chunk missing.
before
after
dual port.
Intake
Beefy connecting rod.
Sq .048
In 74, Ex 103, Tr 122.
This one is getting a 268 piston. More than likely add some bridges on the intake side, rather small tunnel,
Have to see what numbers look like with the 268 piston but I would like to see 77 101 123...
