Early 064 build
mtnwkr
9:16 PM
washington
Tank cleaned up well too.
mtnwkr
9:16 PM
washington
Put the new seals in last night. New fuel and impulse line. Using the old boot for now. Started right up but inconsistent idle when flipped on it's side. Holds a vacuum just fine, even when rotating the crank. I need to borrow my buddies pressure tester to try to find the source.
A change in idle when the saw is tilted on it's side is usually a crank seal right? Maybe I fubar'd one installing it. I was very careful not to flip a lip though!
It is nice to work on a saw that hasn't been dicked with before.
BuckthornBonnie
12:16 AM
Penn Yan, NY
Not always, could be fuel line/filter position or some other cause. Honestly a few of my saws do this and as long as it doesn't race I assume it's not a big deal. Does the idle fall right off? Does it die?
mtnwkr
9:16 PM
washington
It increases, just a bit. I don't have a tach so I don't know how much. Enough to get the chain moving though. The carb is at factory settings.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
11:16 PM
Provencal, Louisiana
Man u got one heck of a deal! Super nice!!
Keith Gandy
11:16 PM
Tip it foward parallel to u and see if it dies or changes tune. Sounds like it may be out alil on the L speed
mtnwkr
9:16 PM
washington
Well, I guess it was the tune. I pulled the carb apart again and cleaned/checked everything again. Put it all back together and it idles and runs great now! Steady idle in all positions.
I went back to the seller the other day and picked up the bar and chain that I had passed on before. $60 with two almost new chains. It's a Stihl 32" bar that had been re-tipped and ground. Was missing all it's paint and had surface rust so I sanded and painted it up so it'll at least look good for now. I want to get a light bar eventually.
Jmssaws has some parts for me to swap to the new style air filter on the way but for now..
The new and improved three saw plan :)
Still need some smalls like cap seals and muffler flange so I can use the new muffler base. I'd like to find a recoil cover that is in good shape also.
So far I only have $275 into the saw/bar/chains.
mtnwkr
9:16 PM
washington
It is a nice saw! Im jealous of the 064 av plate on the top cover!! Lol! I want one on mine!!:D
What do you have on there now? I ran it by the label plate/photo etch dept at my work and they seem to think it would be easy to reproduce if they can get the font right.. If I get one made I'll make extras for ya'll.
Keith Gandy
11:16 PM
