mtnwkr
- 10:24 PM
- Jul 10, 2016
- washington
Tank cleaned up well too.
Can I ask what you used to clean the tank so well?
Not always, could be fuel line/filter position or some other cause. Honestly a few of my saws do this and as long as it doesn't race I assume it's not a big deal. Does the idle fall right off? Does it die?Put the new seals in last night. New fuel and impulse line. Using the old boot for now. Started right up but inconsistent idle when flipped on it's side. Holds a vacuum just fine, even when rotating the crank. I need to borrow my buddies pressure tester to try to find the source.
A change in idle when the saw is tilted on it's side is usually a crank seal right? Maybe I fubar'd one installing it. I was very careful not to flip a lip though!
It is nice to work on a saw that hasn't been dicked with before.
Man u got one heck of a deal! Super nice!!Put the new seals in last night. New fuel and impulse line. Using the old boot for now. Started right up but inconsistent idle when flipped on it's side. Holds a vacuum just fine, even when rotating the crank. I need to borrow my buddies pressure tester to try to find the source.
Tip it foward parallel to u and see if it dies or changes tune. Sounds like it may be out alil on the L speedPut the new seals in last night. New fuel and impulse line. Using the old boot for now. Started right up but inconsistent idle when flipped on it's side. Holds a vacuum just fine, even when rotating the crank. I need to borrow my buddies pressure tester to try to find the source.
are you looking to get rid of that recoil cover?![]()
It is a nice saw! Im jealous of the 064 av plate on the top cover!! Lol! I want one on mine!!Killer saw you got there! Great job cleaning it up and back in service! Nice lineup also![emoji106]
Likewise!It is a nice saw! Im jealous of the 064 av plate on the top cover!! Lol! I want one on mine!!![]()
Beautiful saw Keith!The regular 064 metal tag View attachment 62027
