- 12:16 AM
- Dec 31, 2015
- East Jordan, MI
Yep. My carcasses are all ragged out way more than that one. Guessing yours doesn't have much run time
Damn looks like it was stolen from the Portland area.
Hard to believe but my serial number, as best as I can make out, is 117795019. That's a smaller number than yours shown above and usually means it's older. I would never have suspected that.Here's the numbers if anyone knows the age..
Nice job cleaning it up. Ford light gray implement paint is close.Did some more cleaning tonight. Just wd40 and simple green. I use an acid brush that I cut the bristles short on to get in the hard to reach areas. I decided to just remove the tank because there was so much crap up in there.
Bummer about this.. The rest of the saw is so clean!
Any bright ideas on how to hide it or repair it? Wish those bottom tank cover deals they sell on Ebay would cover it..
I have one!I found the muffler was broken on the corner and was leaking hot gasses onto the case. Anyone have a spare?
I have one!
What's wrong with the boot that's on it?
I have what you need.The fuel and impulse line were dry, cracked and falling apart. I figured the boot would be too, so I ordered a new one, but it's in pretty good shape. I'll use the old one for now while I collect parts to do the flat top conversion then swap to the new carb box and boot, filter base, HD2 filter and cover. If anyone has those parts I'd be happy to buy them off you!
Bring it with you to a local PPG auto paint supplier and get a pint of their lower end single stage urethane. It's around $75 for the paint, hardener and reducer and you can literally paint 30 saws with what you'll get. Tough as nails when hardened as well. They will computer match the color.Did some more cleaning tonight. Just wd40 and simple green. I use an acid brush that I cut the bristles short on to get in the hard to reach areas. I decided to just remove the tank because there was so much crap up in there.
Tape a line across it and paint down from the tape to the base. You can use a brush. You don't need reducer if brushing on. It's better without it.
