- 1:18 AM
- Dec 29, 2015
- Strong Island NY
Still has the 044 boot?
If I cut firewood with that sumbish, I'll have to hire the boy scouts to come pick it up. Ported saws suck that way. lolNice thing is that in 15 min, saw can cut fire wood and then be in cants. That was my goal. 44 carb will be played with this week. Vid next weekend.
If you're planning to run the WT with a stock filter, the 044 carb studs will be too long iirc.
Yup.Still has the 044 boot?
Chain is roundfile.
Saw is gonna need a lot of carb work. If tuned to 14, it’s ok. Anything above that and it starts to pull air like nuts and lean out. I may drill the jet to flow more fuel. I’ll see.
I’m going to try to put another models larger diameter fuel line and filter in.
It’s far from done.
Held less rpm in the cut with the 194 carb. Much better manners. Surprising.
I knew that would get a rise out of you! lol Yea, good thing...Good thing you have Auto Pilot.
Well stability isn't my strong suit either so...
Out of curiosity, have you compared the times and performance using the wt194 with the 026 boot vs the wt194 with the 044 boot? I can't remember if it's doable or not after matching to the 044 bootYup.
I have not.Out of curiosity, have you compared the times and performance using the wt194 with the 026 boot vs the wt194 with the 044 boot? I can't remember if it's doable or not after matching to the 044 boot
