Duane PA 026
Duane(Pa)
It's the chain...
11:36 AM
Centre County
Nice thing is that in 15 min, saw can cut fire wood and then be in cants. That was my goal. 44 carb will be played with this week. Vid next weekend.
If I cut firewood with that sumbish, I'll have to hire the boy scouts to come pick it up. Ported saws suck that way. lol
ABarrick
TacomaTRD98 on AS
11:36 AM
Newville, PA
If you're planning to run the WT with a stock filter, the 044 carb studs will be too long iirc.
I was thinking this saw had the 026 pro/ms260 larger air filter when I posted that. The newer filters have recessed nuts which bottom out on the longer carb studs before the filter tightens up the whole way if you try to go back to the stock carb. I forgot the older small 026 filters had the nuts sticking out the back like that.
stihl_head1982
Here long time
11:36 AM
USA
Chain is roundfile.
Saw is gonna need a lot of carb work. If tuned to 14, it’s ok. Anything above that and it starts to pull air like nuts and lean out. I may drill the jet to flow more fuel. I’ll see.
I’m going to try to put another models larger diameter fuel line and filter in.
It’s far from done.
I heard it when you were testing it on the video. Great build thread though. These types brought me to AS many years ago.
I love the detail, keep it coming.
11:36 AM
Out of curiosity, have you compared the times and performance using the wt194 with the 026 boot vs the wt194 with the 044 boot? I can't remember if it's doable or not after matching to the 044 boot
I have not.
The port shapes now makes it tough to compare. The outer intake port no longer matches the stock 1121 boot and the 044 really needs to be added, with some dirko around it, with the tank off.
