AlexStromberg
Epic gamer
- 7:56 PM
- Apr 12, 2022
- Sweden
Running the 238 cylinder with a 242 crank. The crank is 3mm longer. Will have better rod ratio. It will dwell a little longer on TDC and BDC.What is the 2mm spacer for?
Well I learned something new today! I had always assumed the 234/238/242/246 saws shared the same crankshaft.Running the 238 cylinder with a 242 crank. The crank is 3mm longer. Will have better rod ratio. It will dwell a little longer on TDC and BDC.
Also because finding a 242XP top end is more or less impossible for a sensible price.
Probably the same stroke, like the 254 versus 257 and 262. Just longer rod. Most only look at the stroke and assume it’s in the same case so it has the same crankWell I learned something new today! I had always assumed the 234/238/242/246 saws shared the same crankshaft.
Same stroke but conrod is different length.Probably the same stroke, like the 254 versus 257 and 262. Just longer rod. Most only look at the stroke and assume it’s in the same case so it has the same crank
Still looking for a 242XP cylinder. May buy a AM one but food prices and inflation is sky high atm.Any updates on this project?
Here is more info about 346 stuffers, https://opeforum.com/threads/346-stuffers.16980/will these stuffers fit a 346 crank? Seems the 343R collar is not available/back ordered
No idea, Björn.T knows more about the 346will these stuffers fit a 346 crank? Seems the 343R collar is not available/back ordered
AM Cylinder kit ordered, have to buy something for my own birthday... Do not have high hopes for the quality but will try to clean it up.
Heres a photo of the kit from
WWW.skogsverktyg.se?AM Cylinder kit ordered, have to buy something for my own birthday... Do not have high hopes for the quality but will try to clean it up.
Heres a photo of the kit from the seller View attachment 372586
Asked the owner and he said he doesnt know. I'll see when it arrives.Okay, is it Golf from Turky or Api from India?
I tryed to welld a pop up piston from Aip, very dirty aluminium.
