Christmas 361
paragonbuilder
4:52 AM
Norwich, CT
Ok that's about where I'm at now. Sorry if some of the things I mention are no brainers. Just trying to show it all.
Thanks David! Keep it up. This all interests me. That slag is interesting. So did you cut the scored jug as well? Or will you play with it the way it is?
David Young
Safety First !!!!!!
4:52 AM
vt
The original is not cut and won't be should be ok for 165-170 still.
Here is the neat thing about the slag. It's identical on the other side. Interesting huh?
This is a Stihl jug the other was a mahle.
David Young
Safety First !!!!!!
4:52 AM
vt
The one with slag is the one I sent you
Yes it is. Dall
I have never seen a jug with equal slag on each side. Being they are the same. It would lead you to believe it is on purpose. Seems tough to believe.
Got it back together tonight. Scrounge up a bar and chain. Hope to try to start it tomorrow.
RI Chevy
4:52 AM
earth
Nice thread. Like a test rat. lol
David Young
Safety First !!!!!!
4:52 AM
vt
Gotta push to the finish. I had to pause for other things needing my attention.
I knew I wanted to put a larger carb on this saw from the start. The stock carb is a 15mm Venturi walbro HD carb. The common thing to do is swap for a 290/390 044/046 carb and swap the shafts. I didn't like the way this saw was tuning so I wanted to try a good carb to make sure it was running ok.
Tillotson make change carbs for swap outs. I found a new HE-22a on eBay for 40 bucks. When I took the oem carb off I noticed the tilly had a bigger Venturi already. So I measured them both. Turns out the tilly is 17mm from the factory. I hope this is not a fluke. The h and l were both set to 1 1/4. It needed absolutely no adjustment to start and run. Pretty amazing. I tweaked it a little on the low side. I have a vid. I'll link to also.
