paragonbuilder
- 7:48 PM
- Jan 2, 2016
- Norwich, CT
Being a science nerd, I did some calculations.......
Assume 7.5cm from the muffler opening to the muffler cover. Times this by 2, gives you 0.15 in metres. Divide by the speed of sound in m/s (that being 343). This tells me that the reflected pulse will take
0.15 / 343 = 0.00044 seconds to reach the muffler opening, after rebounding from the muffler cover.
Then consider a 2 stroke revving at 10000 rpm, (or wherever you are for peak torque under load). Divide by 60, gives you 167 revs/second, invert that value, and you have 0.006 seconds for a single rotation.
Since (0.0004/0.006 * 360) = 24 degrees of rotation.
(therefore at 10K, the crank has rotated ~24 degrees in the time taken for the pulse to reflect in the above example)
Feel free to flame me (I guessed one or 2 figuresand rounded up or down in places), but this says to me that the timing of a reflected pulse at saw operating saws probably has some consequence. I can go through the maths in more depth if required.
It may have some consequences, but there is no way to tune a muffler can for a saw. The pulse would be way to fast as your math shows, if it is correct. The pulse needs to be right before exhaust closes and at the desired rpm or it is either hurting the saw or doing nothing.
