Chainsaw grinder questions, tips, tricks, and pics!!!!
greendohn
firewood hack
12:55 AM
east central indiana
Not a good pic but it's all I have for now
chipper1
12:55 AM
Grand Rapids Mi
I will say that you can take advantage of the fact that you can dress the wheel profile how ever you want it.....
I did a little experimenting with the wheel shape myself....when I dressed the wheel for a chisel chain, I profiled the bottom of the wheel a little more square than round.....I know for a fact it produced great results because it was my chain.....
@Philbert have you or any other of you guys played with the wheel profile shape any????
If so what did you do and what were your results??????
There are a few guys who have shaped a pink wheel for grinding rakers. They shape it in a way to get a curved profile with a slight angle just as you would find on many stock chains. I don't care to much about it and grind them at 10 degrees and I'm done.
Khntr85
12:55 AM
Indiana
Ya they did send me a bigger wheel that I will never use, I shaped it for rakers...... however on my personal chains u usually file them off at 0-10 degrees like you said and be done with it....
Philbert
Chainsaw Enthusiast
11:55 PM
East Dakota
Ya they did send me a bigger wheel that I will never use, I shapes it for rakers...... however on my personal chains u usually file them off at 0-10 degrees like you said and be done with it....
1/4" wheel is primarily used for depth gauges, but the 5/16 can also be used for 3/4" pitch chain - I like it for depth gauges due to the wider profile.
Phiblert
Khntr85
12:55 AM
Indiana
Well guys I will have a lot of time to get all my chains (and friends chains) sharpened here this month or next....I got bad news Friday and found out I have a damn hernia..... I don't know how I got along all these 31 years without one until now, but at any rate I do.....they are acting like I may have to get it operated on, and possible down time of 4-6 weeks....I can't believe it.....my supervisor said look at it as a vacation til spring, well easier said then done!!!!!
I have been ordering parts for saws I am goin to rebuild while I am "down", and hopefully I get some more customers that want their chains sharpened........
Icepick69
Fart knocker extraordinaire.
12:55 AM
North Carolina
Is it a lower hernia?
Khntr85
12:55 AM
Indiana
Made me a stand for my HOS. Pretty pleased with the way it turned out. Old girl still works pretty good. I'll definitely be getting a CBN wheel soon.
Very nice, that chain will flat out cut!!!!!!!
How long have you been using that grinder????
I will say, you will love the CBN.....I still use the stone wheels, especially when cleaning out a bad gullet....
cowroy
12:55 AM
Tennessee
I have had it about three years, but haven't used it in about a year because I thought I was gonna have to move and packed a lot of chainsaw stuff up. Things changed and just recently got it back out. I bought it used off AS if I remember correctly. It's not in pristine condition by any means, but it is very well built and parts are still available if needed.
Khntr85
12:55 AM
Indiana
I remember when I was "against grinders" lol..... then I got one and realized that you can turn out a GREAT chain with them, IF you put in effort to learn how to set them up/use them!!!!
I am so glad I got mine when I did!!!!
Khntr85
12:55 AM
Indiana
I've gotta' Foley, had it for so long I can't remember the model #...it's a very well built unit, BUT, it is not "symetric". That's saying you gotta set it up for leftt/right each time.
have had it probably near 20 years with no troubles.
Hey that's a good old grinder I bet!!!!!
If you get a chance get some pics of the teeth after you grind them.....I am a "chain geek" so I like pictures of grinders, and chains LOL!!!!
Khntr85
12:55 AM
Indiana
Oh I meant to ask you, have you had a lower hernia like I have..... just wondering how the surgery went for you if ou did!?!?
I had a buddy stop by that had a hernia by his belly button, he said the surgery wasn't bad, but her was out of work for 4-6 damn weeks!!!!!
Khntr85
12:55 AM
Indiana
Well guys I am waiting on parts to arrive for my saw rebuilds, so I got some time with the grinder yesterday....I ground my dad's chains which are all the .325 RM semi-chisel.....well after I got his chains done I ground a .325 18" RS full-chisel chain that I acquired....
So anyway I tried something just a little different in this chisel chain......I used my "regular" settings which are 30--55--0(on Stihl chain)..... what I did different was grind a little deeper into the tooth, which creates a little more hook or beak...I don't think it is to aggressive, but I haven't cut with it yet.... I also used the stone wheel on the RS(chisel) chain....I used the 1/8 wheel on all these .325 chains.....
The first 2-pics are the RS chain.....the last 3-pics are RM(semi-chisel) chains.....comments, questions, concerns all very much appreciated LOL!!!!!!
RS-chisel chain
RM--semi-chisel
Icepick69
12:55 AM
North Carolina
Yes sir. Two. And go thru the belly button. Be back grinding in no time.
If they cut ya. You down long time.
Khntr85
12:55 AM
Indiana
So we're both of yours the "lower" kind.....do they cut you for that kind....
Can you lift like you used to, once you heal up
