- 9:33 PM
- Dec 30, 2015
- Brewster, NY
Need some advice guys, I'm in the dis assembly process, and I see my flywheel puller will not work on this saw. Flywheel nut came off remarkably easily. Any advice on how to remove the flywheel?
The engine seems to rotate very smoothly despite the slight scoring of the piston & cylinder. The carb and lots of other parts seem to be the same as the 044 (and it has a Walbro carb). Although there is no carb snorkel, the air filter does have a plug coming out in case you want to use one.
The Hi screw was a little less than a full turn out, not sure if that would be enough to have fried the motor. I'll look for other potential problems, and it could also be bad gas.
Also surprised to see the carb nuts directly against the carb!!!! Not the best set up IMO.
Can't believe how restrictive the mufflers are on these things, it must really inhibit performance, it is a wonder they actually run (and may have also contributed to the motor getting too hot).
Also hoping I can just swap the clutch drum with 460 parts I already have to convert it to sprocket drive.
