ammoaddict
- 3:22 PM
- Nov 29, 2017
- Granite Falls, NC
I did my best try to take pics inside the handle. Look right?
View attachment 420380View attachment 420381
You can see it in the other pics I posted. The sheath is up inside of the plastic holder.That looks to be in place, now closeups of the carb side.
So I fired up the nh895 after I looked it over a bit. Started up in 7 pulls, idled good. Reved it up a bit, just didn't sound like it was getting to full speed. Found out the throttle is not opening all the way with the trigger fully pressed. It had a stop it's supposed to hit bit it only gets about 3/4 of the way there. I took a picture it fully pressed. I sent neotec an email but haven't heard back yet. Any ideas how to fix this if they don't do anything about it?View attachment 419898
I think I know your problem now. The return spring inside the trigger is not in it's proper saddle and is keeping you from reaching the full trigger pull which should be about flush with the handle.
It's either that or they really screwed up on the cable/sheath length. Either way a new carb isn't going to solve your problem.
Here is my blue clone at 0 throttle.
At WOT.
Trigger at WOT.
Ok, this is the trigger fully depressed. It has a little lip on the rear that touches the handle. I tried pushing the sheath farther up into the plastic hold where it was even with the top. It wouldn't move at all then, when I pressed the trigger. Makes no sense to me.The carb end of mine doesn't go near that far at wot. I think the trigger goes pretty much flush. I'll try to check it when I get home. Thanks.
At WOT.
Trigger at WOT.
Could be sideways? IdkI noticed something else not sure if it matters or not. I was looking up throttle cables online and the crimped ends look the same on both ends, like yours looks in the pic. The carb end of mine is different than yours. The carb end of mine is more like a T and snaps into the plastic piece.
Won't go the other way.Could be sideways? Idk
Will it fit the other way?
I've never done it. It looks like a pain. Any tips on how it's done?I’ve used T-style ones like that without issue, but I would try replacing it.
Hmm. I can't see what he's doing inside the handle.
Are the hyway cables from HL Supply any good?
what saw is that cloning?83.59 neotecPardon Our Interruption...
www.ebay.com
Zenoahwhat saw is that cloning?
