Another chainsaw dyno...
srcarr52
11:04 PM
Iowa City
Well. The Hooskies Break before going on the DYNO. So...no Hooskies breajing the DYNO. There is usually a Hooskie fix it table set up at GTGs.
STIHLS usually out cutting wood and stuff. Just sayin...LMFAO
Mine are always on the fix it table at the gtg, but just changing chains. If there is any metal in a log at a gtg I’ll find it first!
11:04 PM
I could have sworn I read that a Stihl 661 was run already on the DYNO a while back.
But I never saw the graph.
Should be interesting to see what that one was. We know the stroker was strong on its graph. The more of the same model that is run the better idea we can get of what a good one is, what a average one is and what a turd is.
Stevetheboatguy
10:04 PM
Nw IL
No real "spikes" with the valve. Rather smooth.
Rated for 30hp I'm thinking 30ftlb too they have. A high tq option that is for 60ftlb.
I think it almost has to be a noise/vibration. I'll give them a call and see what they say.
Now that the setup is "right" I hoped it would last longer.
Can the arm be hydraulic or urethane dampened?
Steven
Red97
11:04 PM
MI
Steven
I do think a plastic stop peg may help. It is intended to stop on a kart frame, which has me baffled. How a saw can be that many more vibes than a kart engine. Or even a kart axle. It is designed to run on either.
Rogee
3:04 PM
New Zealand
Well. The Hooskies Break before going on the DYNO. So...no Hooskies breaking the DYNO. There is usually a Hooskie fix it table set up at GTGs.
Interesting to me this . I grew up with my old man drumming this into me every time we ran the saws (028 ,044 and 066)
Time past and I used all sorts of saws just because he made such a fuss of stihl saws and actually found myself choosing to use the huskys much to his worry and they were just as reliable . The 028 was forever having carb problems the 044 would idle till you picked it up and then stall ( 4 times to stihl dealer to sort ) 066 pretty good but anti vibe marginal so yeah I like them all but way more reliable not so sure
Bigmac
8:04 PM
Pretty sure the strongest saw on the dyno so far was a hooskie...by a long shot.
Were is the graph on that one? Probably looks like Mount Everest?Lol Busting balls...pretty sure a stock bort is the best saw made! D553E0BD-291A-450A-AFF2-19DFCDB6E188.jpeg
I have to thank @jacob j. for informing me...this was...the saw to own! Factory rated at 27hp and 40lbs of torque no piped husky can compete...have heard they are banned from all races and competitions...And nobody can get one...
chipper1
11:04 PM
Grand Rapids Mi
I've heard of bolts falling off huskys, but it looks like that 575 in your avatar lost more than a bolt lol.
Rogee
3:04 PM
New Zealand
Its a 576 actually, my favorite saw . I cut that side cover off like that for noodling big logs . Got sick of it blocking all the time so got snd hand cover from local husky dealer and took the grinder to it , no more blockages
chipper1
11:04 PM
Grand Rapids Mi
That's funny, I had 575/576 first, but I figured you wouldn't have done it to such a sweet saw lol.
Those things sure are smooth. I have a cover like that, but I'm pretty sure you have more material on yours yet.
Rogee
3:04 PM
New Zealand
Yeah I run a 16 inch bar and cut the end of the log into blocks , some logs are 1800mm through so 4 to 5 cuts each way and then a 395 with 42 inch to cut them off . 20200424_121708.jpg
SpaceBus
11:04 PM
Downeast Maine
Were is the graph on that one? Probably looks like Mount Everest?Lol Busting balls...pretty sure a stock bort is the best saw made! View attachment 255358
I had to look this up. There are so many clones.
