Another chainsaw dyno...
SpaceBus
12:31 PM
Downeast Maine
Wow, huge gains. Is that a "work saw"? My 395 lives on my Logosol mill, so it needs to be durable enough to live a hard life. Good to see they put out rated power stock. Any Husqvarna 460's been run on a dyno before and after porting? I tried it on the mill yesterday and it worked pretty well for having half the power of the 395.
Bigmac
9:31 AM
Yes I believe it was an older build, every day work saw. Can’t remember any 460 huskies being ran.
SpaceBus
12:31 PM
Downeast Maine
I bought the 460 before I knew any better and it was my first saw. This thing is so heavy and doesn't make enough power to justify the weight. If it could make 5+ HP it would be great on the mill for the smaller logs I usually deal with.
12:31 PM
heres my thought on the whole situation that the dyno gives the answer to and gives numbers of the results
horsepower is the ability to cut faster but torque is what is felt when the chain is loaded and cutting
just like the older saws they wasnt very high revving saws but you could dog them into the wood
some used bigger chain than is used today and chips was bigger and longer bars could be used compared to the cc versus bar length used now
everyone saw what the echo 1201 did as it is a torque slow revving saw but can pull a long bar with no problem
qurotro
Cookie Cutter
11:31 AM
Ar
I recall the 1201 has very little torque.. I didn't save the pic.. someone might post it.
SpaceBus
12:31 PM
Downeast Maine
Horsepower is just Torque over time. I mean that literally as Horsepower is a metric derived from the engine torque. There are two ways to make power, displacement or RPM. A smaller engine can make just as much power as a larger one by increasing the amount of time (RPM) the power is made. Look at Formula One cars that have tiny engines but huge output. This is done now with turbo chargers, but some years ago they just did it by revving V12's, V10's, and V8's to 18,000+ RPM. The same way a tiny motorcycle engine can make over 200 HP naturally aspirated, by revving to the moon. Larger displacement can make the same power at much lower RPM, but larger engines also have more rotating mass and usually the inertia is too much to overcome and they cannot rev very high anyway. The big block American V8's of the 60's usually made about the same power as the smaller displacement small block V8's used in Can Am racing, but didn't rev nearly as high. It generally just ins't cost effective to put racing style engines in everything, despite how much we wish that to be.
12:31 PM
quoting for example
7ftlb, and 7hp stock
a ported 395 as first example of big saw torque and hp i saw doesnt have 7 ft pounds of torque but considered to be a big bar saw
not picking on the 395 because we know he builds good ones
its just a different power curve leaning towards torque instead of hp rpm
Deets066
AKA Deetsey
12:31 PM
