Another chainsaw dyno...
dustinwilt68
Wilt Built Work Saws
3:22 PM
Southwest PA
I have a 462 and I love it, I have always said I would take it over a 572 that I owned for a 20" bar setup, 24" and up the 572 would definitely be my choice. Stock saw at over 7hp for 70cc is probably the most impressive stock saw I have seen to date on here.
Red97
3:22 PM
MI
Isn't the 046 tuned a bit rich here? I thought they were meant to be tuned to 13500?
It was probably close to 12.5-13k
Have A couple of parameters on h data box before recording a run to avoid recording a bunch of useless info.
That is a 2hp start limit. Above 10k rpm
So if they didn't make 2+hp above 10k it won't stsrt recording until the saw hits 2hp. Or somewhere close if it is above 10k
I believe that would only stretch the graph a little, peak power should be close
This too.
Peak power has been very consistent regardless of tune. Power above peak looks much better on leaned out runs.
markds2
7:22 AM
Nelson, New Zealand
This too.
Very interesting, so leaning out a saw to its theoretical limit doesn't necessarily change how fast it cuts. BTW that 572 is impressive! The 044 dual-port run earlier still doesn't come close.
Bigmac
12:22 PM
Oregon
No that’s just peak power, will be a lot of situations where you I would cut faster leaned out and above peak power, especially anything smaller
Terry Syd
5:22 AM
Comboyne, NSW Australia
It's the nature of the carburetor. These little diaphragm carbs don't have an 'air bleed' jet in the high speed circuit to keep the proper fuel mixture after peak power.
I put an air bleed circuit in a Zama to try it and it revved like a motocrosser. Definitely needed a limited coil to keep from blowing it up.
Nutball
2:22 PM
Mt. Juliet, TN
This too.
Have you tried tuning one on the dyno to find the peak power tune that way?
