- 4:36 AM
- Dec 30, 2015
- Brewster, NY
FYI, non ethanol fuel is N/A around here.
I thought NY super unleaded was all E-Free?
You better play nice with my printer Joe.
Some language, but sums up my thoughts on printers...
Diesel has no Octane. It has minimum 40 Cetane.
Yes. That's the station I was referring to. Someone told me it was at all stations in NY. LolIf I recall, in upstate NY (near the GTG) they had 91 E free, but you can not find it anywhere near me. (That was about 2 hours away from me).
That fuel runs real good in saws and OPE.
They don't publish the octane rating for diesel, but of course it has an octane rating.
The reason it is not important is because all diesels are direct injection, which eliminates pre ignition.
The Cetane rating (burn rate) is more important.
Octane rating is simply the temp it takes to ingnite the ignition. The higher the temp to ignite the charge, the higher the octane rating.
A higher octane rating allows higher compression, which can produce more power.
With direct injection, the detergents in the fuel become one of the most important features.
Direct injectors are exposed to intense heat and are therefore hard to keep clean.
They solved the issue fairly quickly Shaun. As did Ford with 6.0 injectors. Sorry your having those issues.
Thus I've been using fuel additive since day 1 in my 2006.
