Another chainsaw dyno...
5000+
9:27 AM
pa
I'd like to see the difference between a normal piston and a dished one. Is the loss in compression made up for by a higher volume of fuel/air mix? Lower compression saws are supposed to rev higher right? So, maybe by using an extra thick aftermarket piston, stock compression could be maintained, but with a much larger volume of mix. And an exhaust port could be lowered, and squish set without having super high compression.
Already done from the factory. Husqvarna 261 dished 262 flat, same cylinder.
sawmikaze
9:27 AM
steeltown
Depends on the saw, but I have multiple Worksaws over 200 psi. As for rpm, I guess one would say safe RPM-not leaned out.
The smaller bore saws have more relative cooling area/bore ratio than the large bores.
Autotune helps one out too, it can overcome the leaning out from too much compression issue by compensating real time.
That’s part of why AT saws will usually beat a manual tune saw, you get the best of both worlds in some way-and it’s safe too. I’ve had to drill the nozzle in some AT saws so that they could compensate and the results were rewarding. For clarification, the jets in Stihl MT saws are in the nozzle side(s).
We have different definitions of worksaws.
sawmikaze
9:27 AM
steeltown
Starting a 200+ psi "worksaw" in a bucket or hanging from a tree isn't going to work so well. Philosophy of use is important and stuffs...
You know how it goes too. Between my 461 porkchop ported and 880 I probably started a chainsaw over 40 times today. It's not a strength thing..I can drop start our 880 with my pointer and middle finger late in the day.
9:27 AM
I wonder if the 6-10 percent gain from one means you can leave work 6-10 percent earlier? Maybe @ayoungtexan can get a job with you Ryan and find out. Let us know if he leaves work earlier. He’s in a hurry because he says he’s too busy to have a job. Lol
sawmikaze
9:27 AM
steeltown
32:1 with HP2 sends you home 11% sooner.
I'll test how thick his skin is for sure..
9:27 AM
I’d agree with you there. I’m not using one 8 hours +a day.
My point was more that one can’t have an absolute value to say yes/no. A 50cc saw with 250psi starts as easily as an 80cc saw at 175.
My shoulder’s done worn out, haven’t slept in 3 nights after starting and swinging a ported 395 with a 36” regular weight 404 cannon around for 6 hours on Saturday. Thank god for decomps too. I’m all about easy starts and lighter saws as the years go by. Really don’t give two shíts if I have to turn in my man card for this statement.
