- 12:32 AM
- Jan 8, 2016
- Farmington, CT
I like the white one!
Thanks for clarification and the link. Good to know that if no C grade is mentioned then it is considered normal not wider clearance. This makes sense to meIirc i read it on some SKF document.I'll try to find it and post it up here.As for explorer bearing,you can type SKF explorer 6202 and the firts result is a pdf from SKF which has all the info about that particular bearing.I remembered a little wrong,sorry.SKF as you will read on the document categorising the clearences as Normal,C2 is lower than normal,C3 is higher than normal etc.When a bearing not mentioning C grade,it is considering as Normal clearence.
https://www.skf.com/group/products/...g-knowledge/bearing-basics/internal-clearance
OD green is needed Matt. Any plans for it?All of those colors of high tops will be available soonhoping for some production next week! Stay tuned!
yes!!!!OD green is needed Matt. Any plans for it?
YepI can do colors...but I have to order 200 units at a time.
You mean the green that will be same as military 288s?
