All Things 288XP
XP_Slinger
They’re Just Saws
10:50 PM
Central NY
Iirc i read it on some SKF document.I'll try to find it and post it up here.As for explorer bearing,you can type SKF explorer 6202 and the firts result is a pdf from SKF which has all the info about that particular bearing.I remembered a little wrong,sorry.SKF as you will read on the document categorising the clearences as Normal,C2 is lower than normal,C3 is higher than normal etc.When a bearing not mentioning C grade,it is considering as Normal clearence.
https://www.skf.com/group/products/...g-knowledge/bearing-basics/internal-clearance
Thanks for clarification and the link. Good to know that if no C grade is mentioned then it is considered normal not wider clearance. This makes sense to me
Mattyo
Youtube speciawist
10:50 PM
Farmington, CT
I'm gonna see how sales go of the existing 4 colors. If they go well then I'll be able to afford another run and ill include the green. If someone wants to send me a low top green top then I'll be able to match it...or at least come close. Gotta sell a few of the existing colors first though:)
