85cc 064 porting
CR500
4:26 AM
Western NY
There must be some kind of misunderstanding,I'm not sending it back.
I know right.... words in series do make sentences.
Had to help a graduated intern out today on a 1025R. His 3pt hitch arms would not fully go down all the way after he replaced the splined shaft.
He was so pissed so I had to help lol, I look at it and asked him did you line up your indexing marks?
I said "I'm never fixed this issue yet and am probably wrong but look at the tech manual and I remember glancing at something in there once to further dampen my social life... it said something about index marks."
Sure as chit there is a note and picture that explains the index marks. Little chit aligned it and it works fantastic.
I mean I screw up and to me those are those life lessons that one has to experience first hand to understand.
Last screw up was not replacing a T-Stat on a 4520 while changing the water pump, Not a huge deal tractor did not overheat but was a smidge warmer than usual but for 14 bucks and being that close I will change that component. Replaced it and it made a difference.
Very good work J... more than pleased with how both or all 3 have turned out!!!!
Sent from my non internal combustion device.
X 66 stang347 X
4:26 AM
Georgia
I'm trying to find some wood big enough to turn it up and make some hard cuts but it's proving difficult.
I port 064's almost every day and this one is up there towards the top I think
I might be asking you some questions in a few months when I have time to finish porting my 064/660. My 460 turned out pretty good for first time port.
jmssaws
Banneded
3:26 AM
Dyno???
I wish I had one.
If yours will tune as fast as his then it's probably ahead but it's hard to say without it here.
I think his is 102.5 123 77 and right with my 066's,I'll run yours some more today and see how it runs broke in
trooney
Admitted Woodaholic
4:26 AM
The land of pleasant living
I didn't get to play with yours enough,it's stout for sure.
Can't remember what I used in it
You remember the timing?
I don't remember but I think you mentioned an old formula. Maybe you mentioned it in a correspondence but got no time today to do it. Got to go to court for a speedi g ticket then on to MR clincals.
Any use results? Have you cut a lot with it yet?
Just broke it out yesterday to cut a couple of cookies with it. It is impressive. I think I'll die with that saw.
4:26 AM
Lol. Be safe. Good luck.
laslabjohn
3:26 AM
central louisiana
I know mine is going to the grave with me. It is insane!! A buddy told me yesterday he wanted to run his ported 390 against my 064 hybrid I told him bring a 395 661 390 it didn't matter. and bring a box of tissue.
4:26 AM
Lol
They are probably all so close that you would need a stop watch with numbers going to the 1000ths to figure out which was faster.
CR500
4:26 AM
Western NY
I wish I had one.
When ia that Dyno GTG??? May send it or the7900
4:26 AM
Send it to us. We have ours coming up on Nov 5 in CT. At Dan's house. Maybe even the dyno.
4:26 AM
Gotta work and make things happen! LOL
The old proverbial Take the bull by the horns. Lol
Even if you only start out small with a few fellow Georgians, it will get bigger each year. Put names with faces. Good friendly chainsaw banter. Run a few saws that you may not have but may want. They are a really good time for sure.
