Adirondackstihl
- 6:39 AM
- Dec 4, 2015
- Upstate NY
I knowNot reusing that one. I got a new one coming
The loose locating pin messed it up good and it ran with the ring ends in the exhaust port for so long it ate the plating.I know
I just can't believe how nasty it looks.
Looks like it came outta a 10yr old saw
A husky would have laid down and soiled it's pants.The loose locating pin messed it up good and it ran with the ring ends in the exhaust port for so long it ate the plating.
I'm still baffled why it didn't hang
They all break. No one brand is the best. Some are just better than others.I'm afraid that might be true but this stihl was about to
I bought a 661 as soon as they were available. It had every problem one could have have for 8 months or so cutting timber every day. Eventually my dealer sent it back cause they simply couldn't figure out what was wrong with it. They gave me a new saw and it's been completely flawless. Redfin ported it for me a few months back and it's a real work horse now. Running at it 40:1 and it hasn't missed a beat.For sure.
If you use it eventually it will break.
This saw has a few miles on it but us nowhere near shot.
I dont really see where the 395 would gain either with that jug J. You dont have to drop the jug that far to make up for the crown difference and the intake isnt lacking with these jugs either.I'm not seeing any advantage to the husky piston over the oem.
New piston is coming
I think Randy tested my 461 with and without it ,did not notice anything different on power by removing it .Someone brought up it was there to lube the pin bearing or cool the piston ,i cant remember now .
25 or so years of the same basic chassis should bring about some "changes" no ?Yeah, I'm just sayin it would be luck of the draw, you never know what your gunna get with a 66
Oh I like mine too,25 or so years of the same basic chassis should bring about some "changes" no ?
Lots of different jug manufacturers as well .
Pretty stout "brick chit house " bottom end and a productive feller saw....don't know if it was ever meant to be "hot rodded" on ...
Yea I got a bromance wit muh O-6-6
It's a stihl thing.....people just won't understand[emoji15]The loose locating pin messed it up good and it ran with the ring ends in the exhaust port for so long it ate the plating.
