50%
Simondo
12:16 PM
UK
Were they showing poor running symptoms ? New ish saws ?
Chief Cat Herder
6:16 AM
Brand new saws........never started. But.......they were both 2014 models.
Dang I was wanting to buy a 550 :(
Go ahead. They are wonderful saws. The 2015 and up have had improvements to the transfer seal, base gasket seal, and the intake.
Miller Mod Saws
Chainsaw Masseuse
6:16 AM
Ravenwood,MO
No this ain't about gains when porting. lol
I tore 4 Husqvarna 550XPs down yesterday. Out of the four, two of them had torn transfer cover seals.
Randy what do you recommend for sealing transfer covers up. I tried motoseal. I didn't like that. Finally used 3 bond something I'll look when I get home. Whatever echo uses is some good *s-wordtt! Lol.
cobey
6:16 AM
Pittsburg, kansas
I would guess the one I'm looking at has been setting a while
Guido Salvage
Supreme saw hoeder
7:16 AM
Farmville, VA
My answer to you
Is to use plenty of blue goo...
Simondo
12:16 PM
UK
Look like the seals were getting damaged by installation at the factory do you think , 2 from 4 is to big a coincidence I think…Worth looking at those seals on older ones I guess .
idiotwithasaw
6:16 AM
Ky
Makes me wonder about mine. But it idles fine now, no chain creep where it's idling up to compensate for a leak. I could be wrong, the funky carb setup has stumped me on how to setup for a leak down test.
Chief Cat Herder
6:16 AM
Genius
First member of ASlite to receive a infraction
7:16 AM
Uncle Willys basement
I ended up getting the flange and two plugs for the intake from Husky. It was money well spent instead of having to make a flange plugs.
Genius
7:16 AM
Before I go any farther on mine I guess I better pull those side covers...
Randy, do you have a preference in motoseal vs a anarobic sealer in this case, or does it make no difference?
