372 Carb swap on 2159
ZukiRyder440
Breaker of recoils
12:38 PM
NY
Welp, hate to say it but I felt no gains in the saw cutting with this carby. Just presented more tuning issues and was kinda sluggish off the low end.. Not really worth it.
Ketchup
Epoxy member
10:38 AM
Colorado
What if you add some intake timing and hog out the transfers?
tickbitintn
11:38 AM
middle tn
kinda big carb for small displacement.
makes tuning tougher and most likely would only benefit at wot and high revs.
would be an interesting swap on a race/well modded saw
ZukiRyder440
Breaker of recoils
12:38 PM
NY
Shaun Carr put a full 372 intake/ carb setup on one of his racer 346s and that thing ran like a scalded dog.
Ketchup
Epoxy member
10:38 AM
Colorado
Not a bad idea but what I would gain RPM but would lose the “lugging” ability.
Your thinking bigger flow channels would increase RPM but lose torque? I would have thought the opposite.
I wouldn’t be surprised if the intake and transfers were larger inside. He has talked about that on some of his other builds. Probably some extra exhaust too.
Benwa
I love the smell of premix in the morning
9:38 AM
Bow
I know everything is relative. Do you have another thread on the rest of the build on this saw? I'm guessing it's not stock. Not everyone wants to share & I totally understand. If we all had an idea of the level/extent of port work done, it might shed more light on the subject. At any rate, thanks for sharing bud!
ZukiRyder440
Breaker of recoils
12:38 PM
NY
I did a thread on another recipe a while back but I have a different recipe now. .030” from band, .030 from. exhaust 105.5, transfers 121 intake 80
More exhaust will probably be good with this carb, im thinkin 102-103. Lowers were case matched,
tickbitintn
11:38 AM
middle tn
That should make good use of the 372 carbs flowing abilities. [emoji6]
At the start of this thread I didn't realize the recipient of this carb swap had been "massaged"!!
Had I realized that I wouldn't have made my earlier comment. My sorries!! Lol
ZukiRyder440
Breaker of recoils
12:38 PM
NY
Your fine mang. I MIGHT try the again but build up another 359 to be my “test mule”
Bjorn
9:38 AM
Sweden
Hello. I am not an expert, but i think you need more blowdown, like 25 degrese. So that small cylinder can handle the big load from the carburator. More fuel mix comming in, more has to get out.
ZukiRyder440
Breaker of recoils
12:38 PM
NY
[Q
