hellomyles
- 3:56 AM
- Sep 8, 2017
- Chattaroy WA
Someone cleaned that cylinder up quick and added a meteor. A few points:
That’s a loss of plating. See the coarse scrathes in the plating below the Ex floor? That will eat up a piston skirt fast. The coarse Nikasil will grind the aluminum down. If you look at your piston, it’s already starting to. Look at the fine scratches on the skirt.
You can run that jug. You’ll need to sand it with a finer grit. I’d personally get a scotchbrite drum and use it. First, wrap it in the new 320 grit 3M clear backed wetordry sand paper. Go in a direction that will keep it wrapped. WD40 in the cylinder, then hone it with the 320, moving up and down. When you’re done, wash and dry, WD40 again, then home with the scotchbrite drum itself. I find that purple is a good start, then finishing with the fine grey.
I’m not that familiar with the model, but I bet the ring/crown of the piston is above that area at BDC. It won’t affect compression at all, and there is enough plating on the sides of it to support the skirt and/or ring.
If the finish above the Ex roof stays intact after the above, I’d use it.
Post some pics when you are done.
Sounds good! Thanks for the advice/instructions!
I’ll take pics when I get to it and post them up.
