346xp bogs when revved off idle (only when started from cold)
old guy
Love me some Husqvarna
7:17 PM
Becker Minnesota
I have 2 oe & 2 ne & none of them do it.
My Poulan 5020 was bad for this but I seem to have tuned it out of that also.
Adamski
Plebus Splederns
1:17 AM
Essex, UK
Are you saying that you can start you 346XP totally cold and as soon as it fires you can pull the throttle and it doesn't hesitate?
I’m not saying that straight from cold to cutting wood. I’m just saying that from cold to blipping the throttle it would bog.
Skinnyminnie
5:17 PM
Southern Oregon
Now I gotta try this on my NE. Never noticed a bog right after starting it but this has definitely got me thinkin'.
old guy
7:17 PM
Becker Minnesota
Ok Kiddies, went out to start those 346's today, 37 degree's f, high wind.
None of these saws have been run in at least a week, some in months. First up, Tree Monkeyed NE, no bog, revved rite off the bottom,seemed a little rich on low tho.
Next up an OE that I ported, now this had a slight bog which lasted all of 5 seconds or so.
Then did an OE & NE both with gasket delete & muff mod, neither bogged, OE seemed a little rich on low.
Also started the 5020 p, no bog, it was also the easyest starter of the bunch, I do like primer bulbs.
Adamski
Plebus Splederns
1:17 AM
Essex, UK
SO back to the 346xp yesterday.
Re-tuned back to factory, opened the high side up to compensate for the muffler mod till it was 4 stroking hard.
Retuned in the wood so that it cleaned up nicely and the low side would give good pick up and then good idle down after a cut.
Left it overnight, fired it up this morning and...
Fired up easily, blipped the throttle. NO BOG...
I guess I had it tuned to rich on the low..
Keith Gandy
Maxima K2 40:1 87 Pump Gas
7:17 PM
Provencal, Louisiana
My NE346xp is finicky on tuning. Several WJ169s and they all tune oddly with the 359xp intake and air filter on the lowside and idle. Not a saw that idles well after a cut if left idling for a longer period
malk315
Running Saws for Therapy
8:17 PM
Lancaster, MA
My 350 does this -- if I let it warm up while on high idle or just wait a bit if I take if off high idle and blip the throttle a bit it is ready for work.
All of my other saws are not this way.
We have a 346 OE and a 346 NE (my brothers' saws) and the OE I noticed needed a bit from cold start to not bog.
The NE is an OE that Neal Murphy turned into an NE w/ just a muffler mod and on cold start is more quickly work ready than the OE.
Not sure any of it means much... all of the saws when warm run great.
Cheers.
