- 7:06 AM
- Feb 4, 2017
- Winona County, MN
Yes - get a gauge for fuel pressure between the filter housing and the injection pump, if you can.....and maybe check the lift pump in the tank.
When I bought my 24v, someone had “updated” from the block mounted lift pump, to the in-tank pump. Problem was, they never removed the block pump, and were pushing fuel through it! I only had around 4psi into the injection pump!
