262 rebuild
10:34 PM
.... for sanding the BASE .... the BASE ....
..... it's just too damned early in the week to be awake ...
I figured thats what you were saying and brilliant idea. But if you can cut round glass from home you are truly badass
But I DO remember a builder video (Tree Monkey) where they used a mandrel the size of the cylinder with self-stick sandpaper to cut the squish band ...
I seen that too.
paragonbuilder
11:34 PM
Norwich, CT
I saw the video as well, took it off and on a bunch of times till he got it just right, very cool indeed, shame you would need so many mandrels though.
If you do a lot of the same saws, make a mandrel. Or do this
Mattyo
Youtube speciawist
11:34 PM
Farmington, CT
Or....take that same setup. ...invert it. Put the cylinder on the bench...piston with sandpaper and wrist pin in cylinder. ...then use a drill with a Husky 350 clutch adapter to grab the wrist pin...and spin :)
PA Dan
11:34 PM
White Oak PA
I seen that too.
I wish I knew someone that cut round glass. After testing the compression on my 262 the other night I stepped on the guage and broke the glass![emoji22] [emoji36]
Johnmn
10:34 PM
Minnesota
This cylinder had bad transfer, I was finishing cleaning that up and the plating peeled a little below the exhaust port. Do you think it's okay to run it? IMG_20170407_115007151.jpg
11:34 PM
This cylinder had bad transfer, I was finishing cleaning that up and the plating peeled a little below the exhaust port. Do you think it's okay to run it? View attachment 64599
I'd use it too. What did you wind up doing to the jug?
What's the squish you arrived at?
I'd get a cylinder brake hone and hone the jug with some oil and the hone. Then wipe clean and do again with scotchbrite.
I've found that those rough sanding lines in the plating will tear up a piston skirt rather quickly.
Sty57
10:34 PM
Land of Cheese & Beer
What grit stones are you using Al?
Johnmn
10:34 PM
Minnesota
Haven't done anything yet, parts should be arriving this week. I will degree the cylinder this week and post what I find and I'll go from there
